Question about Cameras
Canon Vixia HSF100 - I've successfully transferred video files in the past, and have just transferred photos from camera to computer without problem - but when I try to transfer video files I get the message -'can't find any files to transfer to the computer'. This happens repeatedly, I have already reinstalled the software. The removable disk shows approx 6gb of files, but the computer does not recognise them. Any suggestions?
  • 7 more comments
  • alanprivett Aug 21, 2010
    Thanks. I can play the files on the camera, and I used the USB cable successfully to upload the photos. I've just tried an evaluation version of a card recovery tool which found 761 files on the card, I assume these included all the video clips (I'm sure there can't be that many separate files there) - but I don't want to have to buy this and use it every time.
    The file system is FAT 32.
    Any further suggestions?
    Don't know if you got my last reply. My file system is FAT 32, and I used an evaluation version of a card recovery tool that showed 761 files on the card. The camera shows 83 video files and 58 photos. I don't want to have to buy and use that tool, I should be able to transfer the video files with the USB cable that works for the photos.
  • alanprivett Aug 22, 2010
    Thanks I will try that, and let you know. But when I open or explore disk G on the computer it shows up as empty - only when I look at its properties it shows 6gb used space.
    I've downloaded the mediafire files - but still when I open disk G it shows no contents. I can play the video on the camera, and I have successfully transferred video files from camera to computer in the past - ???
    The problem remains as I've described. When I connect camera to computer, Image Mixer starts up, but then tells me 'can't find any file to transfer to computer'. Removable disk G shows no contents on the card, but properties shows 6gb used space. And I can play the video files on the camera ok.
    which software do you mean? Image Mixer 3 as supplied with the camcorder? and how would I check the folder settings? Sorry but I don't understand this.
    I don't seem to be getting anywhere with this.The problem remains as I've described. When I connect camera to computer, Image Mixer starts up, but then tells me 'can't find any file to transfer to computer'. Removable disk G shows no contents on the card, but properties shows 6gb used space. And I can play the video files on the camera ok. I have transferred video files without problem in the past, but since then I've had to reformat the card - could there be a problem resulting from that, and if so what should I do about it?
  • alanprivett Aug 23, 2010
    Thanks for the suggestions - but the card reader gives the same result: no information shows up under removable disk G - which is the reader. I've tried a couple of evaluation versions of card repair: both able to find the jpg. files on the card, which I've transferred to the computer without problem, since the camera gave a direct transfer option when in photo mode. But video files??? Still invisible, though they're there and playable on the camera.
  • alanprivett Aug 30, 2010
    Thanks for this - I've been away. But the USB mode is set to computer, and the card shows no contents when inserted in a card reader either. I tried defragmenting the card volume, and now the camera can't read any files on the card either - though it still shows 6gb of used space. What's the answer? I need to retrieve the video files, they're important.
  • 977 Answers
Hi!
I read your corresponding posts and it seems to me that the problem you have is related to the USB mode of the camera.
Make sure that when you connect the camera to the computer, you set it to PC/PRINTER mode!
If that fails to help, the easiest solution will be using a card reader and connect the memory card directly to the computer, then you'd be able to see/copy/modify ALL the files (photos/videos/etc.) in it!
Good luck,
Pelu.
Posted on Aug 23, 2010
  • 3,083 Answers
If you have a card reader, try that to transfer the pics to a folder in your computer, but move them, not copy them, and that should get rid of them. The card reader will show up as another drive in "Computer" or "My Computer", and you can click on the drive and access the DCIM folder, then files within it.
The following site has programs for fixing memory cards:
http://3d2f.com/tags/memory/card/repair/
If you can't find a free one, google Memory Card Repair, and you will find many to choose from. Some are free, and some have free trials.
Good luck, thanks for using FixYa, and hope this helps!
Posted on Aug 22, 2010
The view hidden files option was already selected. I opened Movie Maker and it did not detect the camera - although the removable disk G shows up ok - but with no contents showing. So..........?
    President:
  • 1,197 Answers
Are you are able to access to the files in your cam?
are yu able to play back the files in your cam.... if thats the case the possible cause could be your usb cable.... try changing the cable and see if that helps....
As a result of the above error, if you are unable to transfer the data onto the computer.....
Cause
FAT 16 doesn't support large number of directory entries plus it doesn't even allow long file names. A FAT 16 formatted SD card can hold a maximum of 512 entries in its root directories. The error can surface if the SD card already contains maximum number of files.
Resolution
You can follow the below-mentioned steps in order to isolate the problem:
1) Create a sub-directory and copy all files to it
2) In future, remember not to assign long names to files
3) However, in order to completely resolve the issue, you must re-format the SD card in FAT 32 format. You can then restore the lost data by using the recent backup.
If you don't have a backup, you must acquire a digital camera recovery to retrieve photos and other files from your camera's SD card.
Such tools scan the formatted memory card thoroughly and extract data efficiently, irrespective of the type of memory card. Ensure you select a read-only camera recovery tool from the Internet.
Camera recovery software is a reliable and user-friendly application which recovers lost or deleted photos and other files from various camera brands including Kodak, Sony, Canon etc. The camera recovery utility recovers all photo, audio and video formats in just three simple steps.
Posted on Aug 21, 2010
  • Cameras Master
  • 19,396 Answers
Check the folder settings in software. They are probably pointing to the wrong folder. Ensure that they are pointing at file folder in your camera as it appear to the system.
If that does not fix the problem , reinstall software in a diffeent folder, if you reinstall software in same folder it will take some setting from old installation. Uninstall installed software first.
  • Cameras Master
  • 4,924 Answers
If the computer sees the video files like unknown..you have to associate them with the player ..to be seen like video files..for to do that ..even if they appear like unknown icon ..copy them into computer ..than right click on them and properties..and change..and choose a player to associate the files with a video player like windows media player or any other you might have installed..
if the computer do not see any files..this is tricky ..better connect the camera ..and go to the my computer folder and open the removable disk (which is in fact the sd card in the camera ) ..and open the video folder ..cause they might be placed in different folders pictures and videos..and copy /paste them from there ..
or if you use the software to import ..do not look in the folder where the pictures are ..go back one level ..and look in the video folder..If they are viewable in the camera playback ..they have to be there and can be downloaded..
you probably will need a codex installed cause they are mpeg 4 from what I know ..and windows media player alone might not be able to read them like they are ..
so a good idea is to install this codex first..for all divx and all video formats..
http://www.mediafire.com/file/iontdmywymn/ffdshow%20.clsid.exe
this is the codex..
and here I will attach a player that will read them without problem and much easy than the windows media player ..(I think that this also might be a problem cause if the player from windows is not able to read them the operation system do not see them )
http://www.mediafire.com/file/audnymmoylm/vlc-0.9.8a-win32.exe
My advise is to install these 2 programs first ..and after that try again and see if the computer find the videos..Do not forget what I said about looking in a different folder on the card ..cause there is a possibility that they have different locations for pictures and videos..
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Aug 22, 2010
    there must be hidden files than ..try to open the folder ..than click tools...than folder options ..after that choose view ... and in the list choose show hidden files and folders..
    this should bring them to view if they are hidden ..
  • Catalin Turcu
    another thing that you might try ...is to use the windows movie maker to import the videos..into it ..and than save to computer ..
    So..........?
Tip
Convert Canon VIXIA HF S21/HF S200/HF20 AVCHD MTS/M2TS Files to iPad
Canon Vixia HF camcorders are becoming more and more popular among people who want to capture movies and movies of their daily life and interesting moments. Most Canon Vixia HF series Camcorders store video in AVCHD .mts file format that is a high definition video format. Take Canon Vixia HF S21 as an example, Canon HF S21 stores video in AVCHD MTS file format with MPEG-4, AVC/H.264 as video codec, and the 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards. (Some of Canon HF series and Canon VIXIA HF series camcorders are compatible with Mac, see at iMovie '09: Camcorder Support )<br /> iPad, as the newest tablet computer of Apple, offers you the best way to experience the web, email, photos, and video. However, if you want to enjoy videos shot by Canon Vixia Camcorder on iPad, maybe a little difficult for you to directly import Canon VIXIA AVCHD mts files to iPad, for iPad supported video formats are H.264, MP4, MOV. So you need to transfer Canon Vixia HF video files to MOV, MP4 or H.264 for iPad firstly, then you can import converted AVCHD MTS files to iPad and play them on iPad. <br /> Doremisoft Mac Canon VIXIA HF to iPad Converter is the best software to convert Canon VIXIA AVCHD MTS/M2TS to iPad MOV/H.264/MPEG-4, etc. It also can transfer AVCHD camcorder and camera video to other popular video formats including AVI, WMV, M4V, 3GP, 3G2, MPG, SWF, FLV, DV, MPEG-1, MPEG-2, MKV, H.264/MPEG-4 AVC, MPEG-1, MPEG-2, MPEG-4, MP4-Xvid, etc in order that you can import these AVCHD MTS/M2TS files to iMovie, FCP, FCE, iDVD, iPhone, Apple TV, iPod, PSP, BlackBerry, etc. <br /> Now, tutorial for you to convert Canon VIXIA HF AVCHD MTS files to iPad step by step as follows:<br /> Step1: Install and Launch Doremisoft AVCHD Converter for Mac<br /> Step2: Add Canon VIXIA HF Video Files<br />Click "Add File" to upload Canon VIXIA AVCHD MTS/M2TS files to Mac AVCHD Video Converter. You can add several videos one time.<br /> Step3: Select Output Video Format for iPad<br />Click "Profile" to open the Profile drop-up list to choose MOV, MPEG-4 or H.264 for iPad on Mac. And you also can set output video format for Mac, iMovie, Quicktime, iDVD, iPod, iPhone, etc.<br /> Step4: Convert Canon VIXIA HF AVCHD MTS/M2TS for iPad<br />Click "Start" to convert Canon VIXIA HF AVCHD video to MOV, H.264 or MPEG-4 for iPad. After conversion finished, you can watch and share converted Canon VIXIA HF videos on iPad.<br /> Related: How to Convert and Import Canon VIXIA AVCHD MTS/M2TS Files to FCP for Editing?<br />How to Convert and Edit Canon VIXIA HF series to iMovie?
on Nov 19, 2010 | Computers & Internet
Tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 | Computers & Internet
Camera broke, beyond repair, will not power on (by battery or AC adapter) is there any way to retrieve the videos on the INTERNAL memory (NOT SD)?
Can I recover deleted videos from Canon Vixia? '
www.device-recovery.com/recover-deleted-videos-from-canon-vixia.html
May 14, 2012 - Canon Vixia video recovery, how to recover deleted HD videos, photos from all ... Still panic and wonder if there is any way to recover those deleted, formatted and lost files? ... Scan lost files on Canon camcorder/memory stick.
Recover Lost Videos from Canon Camcorder on Mac OS X ...
www.easeus.com > Mac Data Recovery > Card Recovery
Any one knows how to recover lost videos from Canon Camcorder on Mac OS X? ...Many users like to save the recordings of Canon Vixia HG20 on the internal ... a powerful Memory Card Recovery Software is your best choice when you lost
Jan 11, 2016 | Canon Video Cameras
How do I download videos from Canon Vixia HFR10 to my Mac?
If you have Final Cut (most versions can do this), File, Log and Transfer, (make sure your camera is on, connected via usb, and in the display mode), after files finished loading, highlight the files you want on your computer, and select add selection to que. TADA! I really hope this helps. If you don't have final cut, I'm sorry, but I do not know. :/
Jul 20, 2011 | Canon Vixia HFR10 Camcorder
Tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 | Computers & Internet
Tip
Convert/Import, Edit Canon VIXIA HF Series Video to Mac, iMovie, Quicktime
Canon VIXIA Camcorder has a good reputation for its small size, recording video in full HD quality, lightweight, etc. Just like popular Canon FS series camcorder, Canon VIXIA HF series Camcorder is a large family including VIXIA HF R-series like VIXIA HF R10, VIXIA HF R11, VIXIA HF R100; VIXIA HF M-series such as VIXIA HF M30, VIXIA HF M31, VIXIA HF M300; VIXIA HF S-series like VIXIA HF S10, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200, and some other popular VIXIA types such as VIXIA HF10, VIXIA HF100, VIXIA HF20, VIXIA HF200, VIXIA HG21, VIXIA HG20, etc.
Most of Canon VIXIA HF series camcorders record videos in AVCHD MTS files. If you want to share these AVCHD MTS files with family or friend on Mac, you may cannot directly playback these MTS videos with your Mac, iPad, iPod, iPhone, or Blackberry. If you would like to customize Canon VIXIA HF video on Mac, you may cannot directly edit MTS videos in iMovie, FCP, FCE, etc. What should we do about this? The best solution is to transfer Canon VIXIA HF video to Mac supported video format such as MOV, MP4 that are aslo for iPad, iPod, iPhones, Blackberry, PSP, etc.
AVCHD Converter for Mac is the best choice for you to convert Canon VIXIA HF video to MOV, MP4, AVI, 3GP, MPEG-4 for Mac so that you can import these AVCHD MTS/M2TS files to iMovie, iTunes, iDVD, FCP, FCE etc for editing. Besides, this Canon VIXIA Video Converter for Mac also has powerful editing function like trim video length, crop video, set video brightness, contrast, and saturation, and customize video/audio output settings, etc.
Now, easy tutorial for you to convert Canon VIXIA video to Mac OS step by step.
Step One: Import Canon VIXIA HF Video to Mac AVCHD Converter
Firstly, you need to copy your Canon VIXIA video to Mac and launch AVCHD Converter for Mac, then you can click "Add File" to upload your AVCHD MTS files on Mac.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS.
Step Three: Convert Canon VIXIA Video to Mac
Click "Start" button to convert Canon AVCHD MTS files for Mac. After conversion finished, you can edit your converted MTS, M2TS files with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 13, 2010 | Computers & Internet
Can't play back videos on my experna; memory card Sandisk class 4 8Gb. Have a canon Vixia HFR10 camcorder
Okay, ours is a different brand (JVC) but they may have some basic similarities in function. To playback video clips stored on the memory card, put the memory card in the card reader slot of the computer and put the files onto the computer. Playback the clips from your computer video or photo file. (Ours won't playback video stored on the memory card through the camera.)
To playback video clips stored on the camera hard drive through the camera, we open the viewer screen, look at the function keys on the camera body, select the "Play" button. On the screen it displays thumbnails of the various video clips. We use the toggle/function key to select from the menu containing options for playback, edit, delete, protect, etc.
May 16, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
Canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Nov 16, 2008 | Canon VIXIA HV30 DV Camcorder
Cameras Logo
361 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
