Flat line on tv picture tube - Televison & Video
  • rdpin Mar 16, 2009
    I have a Toshiba 36A40 regular tube TV that I bought about 9 years ago.
    When I first turn it on, it takes anywhere between 20 minutes and 45 minutes for the full screen to come on. During this time, THERE IS SOUND BUT NO FULL PICTURE, just a horizontal white line across the middle until the picture finally flickers and comes on.
    Any ideas??? THANKS
  • 8,617 Answers
Need to replace the vertical output IC. Thats usually the problem when ever you have a line running from side to side across the screen in the middle.
Posted on May 03, 2008
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Stand by red light is flashing, unable to turn on tv - needs servicer???
9 times is a high voltage shutdown, usually having to do with the 200 volt line going to the picture tubes which were a constant problem in that model line.
on the crt cards there is a video output ic which has shorted causing the 9 blink error code.'
The chip has shorted because the picture tube is bad.
It can be any one of the 3 picture tubes in there and must be isolated by a process of elimination, just to get started.
the worse news is the picture tube itself is rarely available, and then only as a "rebuilt tube".
This is because these tubes failed so frequently in this model. CRT's themselves are becoming rare in general.
This is not a job for anyone other than a certified tech, but be advised...the likelyhood of saving this TV is very slim and would be cost close to the price of a new flat panel tv.
if you proceed, you will likely only get as far as paying a technician for an estimate who will simply deem the TV cost prohibitive and condemn the unit.
Jun 07, 2011 | Sony KP-51WS520 51" Rear Projection...
Standby light blanks 9 times and pauses - kp-51ws520 - no picture
Apr 12, 2011 | Sony KP-51WS520 51" Rear Projection...
Picture is compacted vertically in center of screen redgreenblue
your vertical hold is out on the tube. new tube is needed. cheaper to get a new flat panel tv.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
Tv keeps flat lining and shrinking picture
If this is a crt tube tv. Your vertical ic is loosing its connection with the board. Better to quickly resolder it or reflux it with a new lead. Before the IC fail for good.
Apr 28, 2009 | Toshiba 36AF43 36" TV
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Televison & Video Logo
764 people viewed this question
Top Televison & Video Experts
Electro Med Services...
