Question about Toshiba 65H84 65" Rear Projection HDTV
Picture image is unsettled when you 1st turn on the TV - Eventually gets better after warming up for 15 minutes. Rear projection HD 56" screen - About 8 years old.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
LINES or noise from left to right etc. This is a classic problem in a lot of these sets--that this clears up after a while is also typical---the period will gradually get longer and longer for it to become normal.
This set uses a Hyper board for all signal from all inputs---about two dozen tiny surface mounted filter capacitors on that board---they dry out and lose value---flat caps will when hot attempt to regain some of the value they should have.
Board is no longer available from Toshiba, only way to fix is remove one in set and send out for repair to someone like PTS Electronics.
I have seen experts try to replace the tiny caps--usually several are off value or open---cheaper to send board out. Last one I saw cost was about 200 for rebuild, keep in mind same problem will happen again in 5-8 years.
Let me know if you have questions and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 21, 2010
  • meeeach Feb 15, 2011
    Toshiba 65H84 65 in. Rear Projection HDTV Television , same problem as Jean http://www.fixya.com/support/t5686528-pi... is this the board that needs to be repaired http://www.moduslinkptstvboards.com/2314...
  • aahluvscab Dec 09, 2011
    Will the tv eventually go out or will it last a little while this way?
We're having what sounds like the same problem. I'm going to try an upload two photos.
SD Tech, I Googled PTS Electronics but can't find direct contact info. Also, I'm fairly handy and would loike to remove the board myselfPicture image is unsettled when - jean_chamble.jpg
Posted on Nov 15, 2010
  • jean_chamble Nov 15, 2010
    I forgot, not only do we have the same problem, the lines do not go away.
  • Davsew03 Nov 16, 2011
    This looks like my TV, what's the solution? Sending the board off to be fixed, which board?
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
My 56 Gateway rearprojection tv takes about 10 minutes to turn on. When you hit the power button I can hear a loud humming sound and in about 10-15 minutes the tv turns on. After watching tv for about 30...
take to a shop for 29,95 to check. vise 150.00 to check in home. call around some charge more. Its better to know , than guess on that kind a money. age is a factier in repairs.
Jan 03, 2018 | Gateway DLP56TV 56" Rear Projection...
50 in sony rear projection tv screen has yellowish or greenish tint in center 1/3 of screen
OMG. If it is a rear projection LCD then you have a bad light engine. Any good repair shop will repair for $200-250.
If its an older 3 tube projection then you have contaminated coolant in one or 2 of the picture tubes. Just drain out the fluid and replace with new. Should be able to do in 15 minutes. total cost $45.
Feb 25, 2010 | JVC AV-56WP84 56" Rear Projection...
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
No picture on tv all three lights flashing on front of tv.
Three blinking LEDs mean lamp may be defective replace the lamp.
May 25, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
P56930BL focus problem
Sounds like you need a new focus block, they are actually cheap. If you need a link on where to get one let me know.
Jun 20, 2008 | RCA P56930BL 56" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Mar 17, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Lamp problem?
your picture processor is broken. we have the same tv, after 1 year problem started. we got a tv tech out and he looked at it and said it would cost $1800 to fix and this is after we bought a $400 bulb from sharp. this problem is in many of the same tv's of this exact model as we've invstigated and sharp is unwilling to help. there should be a classaction suit or recall for this exact tv.do not buy bulb , it will not work
Aug 18, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Red screen
It sounds as though your Picture tubes are getting weak or theres a bad capacitor in the screen drive circuit. The only way to tell would be to call in a tech to diagnose this problem with his test equipment. A tv set is not a place for an unexperienced person to play with. Good Luck
Jul 29, 2006 | Sony KP-41T65 41" Rear Projection...
Toshiba 65H84 65" Rear Projection HDTV Logo
407 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
