Question about Acer Computers & Internet
My acer aspire netbook turns on but just stays on a black screen whats wrong with it
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 21, 2010
Aspire One PC Notebook Your question about Aspire One PC Notebook has been posted. Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 15, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hello. I have an Acer Aspire One netbook, about 2 years old. While I was reading a pdf document the screen suddenly flashed a message saying "going to hibernate now" or something similar, and the...
Unplug the netbook from the AC adapter and remove the battery. Replace the battery, charger, and power the netbook back on. This is called a hard reset.
Apr 13, 2011 | Acer Aspire One PC Notebook
My netbook won't turn on, it will get to the black acer start up screen, then the screen will go black for a while and then it will go back to the acer start up screen again... I tried pressing f2 to see...
when you turn on the Acer Netbook... Continuously press F8 until you see a Menu... from there you can do Start Up repair, or what i suggest is boot to last known Good Configuration (this Menu is known as the Recovery Console)
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I turn my Acer on, the light comes on but the monitor stays black. This happens even if I have it plugged in to the ac adaptor. Is the monitor broken? It has been plugged in for charging for some...
The problem here is the Acer Aspire One suffers from the black screen of Death, it's a BIOS error I have three Acer Aspire One's and I have had this problem and fixed it.
Here’s what you need:
  1. USB Memory stick (just need one as low capacity as 128mb)
  2. Another PC with a net connection
  3. WinZip, WinRAR, or some other program that can extract zip files.
  4. A quick visit to www.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on/stays black.
And here’s what you do:
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110 or 150 or 751)
  2. Click on the tab on the download area that reads ‘BIOS’ even if it looks like you can’t click on it (their site design grays it out but it’s there) and download the BIOS file numbered 3310 (it might have changed version recently but do it) and don’t worry, you can trust this file, as it’s from Acer directly.
  3. Extract the zip once downloaded and find in the DOS folder the files ‘flashit.exe’ and 3310.fd
  4. When you’ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  5. Put the USB in the Aspire One and hold the keys ‘FN’ (function) and ‘Esc’ (escape) and keep them held when you turn the laptop on
  6. Watch the power button and when it starts flashing, press it once (DO NOT DO ANYTHING ELSE)
  7. You should notice the USB (if it has a light) blinking as well…
  8. The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
This is tried and tested. It took me three times because I messed up step 6 a couple of times but my netbook worked after the third attempt.
May 21, 2010 | Acer Aspire One PC Notebook
Aspire One PC Notebook: My acer one aspire turns on but screen stays black...
Try this for the black screen of death problem...
  1. USB Memory stick (as low as 128mb)
  4. A quick visit towww.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on.
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110/150/751)
  4. When you’s ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  7. You should notice the USB (if it has a light) blinking as well… The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
It took my three times but this IS the proper solution! I am now very happy with my Aspire One that still works!
May 16, 2010 | Acer Aspire One PC Notebook
My acer aspire ones screen is just staying black and wont reboot what do i do ?
I have the same problem! I received a response to my email telling me to disconnect adapter and battery, hold the power button 30 minutes, connect ac (make sure it's plugged), turn on, wait 1-7 minutes, then attach battery after windows boots. After several tries, it still hasn't worked. When I turn on the system, my power led stays green, but the hdd indicator is not lit. My battery can still recharge, but the screen is still black, and there is no sound.
Apr 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen is blank when machine is turned on
There is occasionaly a BIOS error that can cause a black screen on the aspire one.
you can find the BIOS update here:
http://support.acer.com/drivers_download.aspx
And you can find flashing instructions here:
http://netbooks-us.custhelp.com/app/answers/detail/a_id/66/session/L3NpZC9nSzRWRzNTag==
Jan 14, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
