Question about Bosch Coffee Makers & Espresso Machines
When I insert a tassimo disc, or the cleaning disc, the top green light stays dark and the right green lights up. Pressing to start makes the light blink, and after a short while, the yellow light appears. No water is processed.
  • 944 Answers
The yellow light appears when the water level is low.The water will be send through the valve.Please clean the valve and the Use distilled water not the soft water.The flow of water is blocked please clean it.Yellow will take the machine to stand by mode
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 22, 2010
The orange light on the start button comes on and nothing happens
prepare machine for use first.
half-fill water tank, switch on unit and insert yellow TDisk (service disc) barcode down. Close the locking unit securely loud click, press green light repeat these steps 3 times. After that you will have the stand by orange/amber. Remove the Service Disc and store in the recess behind the water tank, Insert a Coffee Disc, close the brewing unit with click and green light should be on. press and it should work.If not go to shop where pruchased. Warranty.
Dec 29, 2012 | Braun Tassimo Espresso Machine/Coffee...
Yellow light keep coming on when i try to make a cu of coffee
the optical sensor that reads the bar code could be dirty. My Tassimo sensor also needs to be "wet" before the disc is inserted to work properly. Seems that the plastic of the sensor has started to degrade and clouded over. When you clean the sensor just use soap and water. Nothing abrasive.
Feb 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Jan 14, 2011 | Braun Tassimo Espresso Machine/Coffee...
Hello - I have a Bosch Tassimo that has worked fine for months. This morning, when placing any beverage disk into the fold down top in order to brew, the LED indicator light remains yellow instead of...
Mine does this all the time. There are several reasons why this happens . If you look at the machine from the front, find the part that pierces the disk at the top and dispenses the coffee at the bottom. This snaps in and out for cleaning. Push up on it until it pops out. If you have just used one of the hot chocolate discs and did not run the cleaning disc or rinse this part afterward, the chocolate clogs the spout and you will have to clean it out. If it is not due to a hot chocolate disk, I usually find that the small piece of aluminum that is punched out at the top has either gotten stuck inside the dispenser spout (sometimes more than one is in there) or is laying partially over the mouth in the center. The spout must be clean/clear before the green light will come on. After you pop it out, spray it out or push a pipe cleaner or other sharp object through it to clear it (skewers work, but I have to move it around to get anything that is stuck to the sides). After it's clean/clear, snap it back in place (make sure that it snaps into place). If that does not work, wipe the top and bottom of the disc shelf (there are sensors there, too). If you have had your machine for a long time (like I have), and none of that works, you may have to jiggle the top piece that covers the disc to wake the sense up. Good luck!
Jan 12, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
All the lights are flashing on my Braun Tassimo TA1200 and will not make coffee
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Aug 07, 2009 | Braun Tassimo TA1200 Espresso Machine
Yellow light comes on to heat water, but does not change to green
I would try opening and closing the disc enclosure latch-- this triggers the machine to re-read the barcode and start a new cup of beverage. If the machine perceives that water needs to be heated more, the yellow light to should flash and the cycle to green when ready. If the water is already hot enough, when you close the latch, it will flip right to green.
Give this a try.
Also see my solution to my own problem with the water reservoir: http://www.fixya.com/support/t1267835-braun_tassimo_model_type_3107_brew
Gazzer.
Jan 07, 2009 | Braun Tassimo Espresso Machine/Coffee...
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
215 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
