Question about Garden
What are valve clearence specs for a Kubota WG600-B liquid cooled gas engine?
martin538
  • 117 Answers
SOURCE: valve clearences,on 1999 vitara 1600cc
Posted on Apr 10, 2009
  • 110 Answers
SOURCE: I need the torque specs for a 3 hp Briggs and also
a 3 hp briggs has about 4.75 inch lbs of torque at the PTO at 3200 rpm.If its an older model engine, reffered to as an L head, Where the valves are mounted in the block next to the cylinder the valves would be set at005 intake and 007 exhaust. If its a newer Over head valve model you would be safe at setting both valves at 005 at TDC remember to use blu loctight on all threaded locations
Posted on Nov 09, 2009
ckoira57
  • 267 Answers
Valve Clearance Cold - Inlet : 0.07 -
0.12 mm
Valve Clearance Cold - Exhaust : 0.12 - 0.17mm http://www.motorbikespecs.net/index.dyn?flag=2&model_id=2147939&make=Yamaha
This site gives most tech. details required for your bike. Cheers.
Posted on Apr 29, 2010
Woods Goat
  • 85 Answers
Intake and exhaust: .003-.005"
*Help me out. Rate me!
Posted on Jun 13, 2010
  • 2841 Answers
SOURCE: 2006 17.5 briggs and stratton ohv need specs on
Remove the spark plug. Turn the flywheel until the piston is at Top Dead Center (TDC) on the compression stroke. Continue to turn the flywheel until the piston drops down 1/4". Set the intake valve at .004" - 006". Adjust the exhaust valve to .006" - .008". You can use a pencil to know that the piston down 1/4". Just put it in the spark plug hole against the top of the piston and then place a mark on the pencil at the lip of the spark plug hole. Now measure up 1/4" and place another mark. Turn the flywheel unit the second mark is flush with the lip. The feeler gauge should be snug but move freely when adjusting the valves. Double check it after locking the rocker arm nut down.
Posted on Oct 18, 2010
Valvelashclearence
I need to know the model series of the engine, but you can look up the specs once you have that at the link below. http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Jun 08, 2017 | Cars & Trucks
My kubota GS 160 need both valves shaved. Apparently Briggs use .010 on both and tecumseh use one at .008 and one at .012 so I'm assuming that's roughly within the guidelines as can't find specs.
kubota - kosfa industrial co., ltd.
www.kosfa.com.tw/_english/02_products/01_list.php?fid=3&carid...
If you have questions about the models or products that you cannot find in our ......Model: GD75; Category: ENGINE VALVE; Description: SHAVE TYPE S45C; ... Make:KUBOTA; Model: GS160; Category: ENGINE VALVE; Description: IN & EX.
how to adjust valves on honda gx, or chinese replicas ...
? 5:49
https://www.youtube.com/watch?v=xmXr4U5R8ak
Sep 18, 2011 - Uploaded by enginerepairguy
You need to fixed the camera or some one help .... Can incorrectvalve clearance cause this type engine to start on choke, and immediately stop? .... Honda gx160 carb rebuild part 1 GX200 GX240 GX270 GX340 GX390 ...
Jan 19, 2016 | Tecumseh Garden
Bike runs but when gets warm shuts down will start in about 15 mins when cools
Valve clearence is to tight, compression then becomes zero when hot and when cooled down again compression is back. Adjust clearence maybe 0.05 mm more up, but check all valves an all cylinders.
You could have a burnt seat too.
Aug 05, 2014 | 1984 Suzuki Gs 550 L
How many cylinders in the vs800 intruder 1995 i dont want to mess up the bill of sale
1995 Suzuki VS 800 Intruder MANUFACTURER SPECIFICATIONS
Manufacturer - Make - Model - Year: Suzuki VS 800 Intruder 1995
Motorcycle Style: Cruiser
ENGINE SPECS
Engine Type: 805 cc, 4 Stroke - Liquid Cooled - V Twin
Engine Bore and Stroke: 83 mm x 74.4 mm
Valves 4 valves/cylinder
Claimed Horsepower: 55 hp (41 kW) @ 7000 rpm
Maximum Torque: 64 Nm (47.2 ft. lbs) @ 5000 rpm
Transmission type: 5 speed
Final Drive: Shaft
Jul 06, 2014 | Suzuki VS 800 Intruder Motorcycles
I need to adjust the valves on a 2002 club car kawasaki gas engine
you can check the net for valves clearences inlet;exaust.to be really exact.need to know the motor you have
Jul 17, 2012 | Motorcycles
How do I adjust ZZR1400 valve clearence
The valve lash adjustments on these bikes are done with shims on a COLD engine.
Intake valves 0.15-0.20
Exhaust valves 0.22-.0.27
Check the specs on your emissions sticker to confirm...California bikes are subject to change.
If you are not familiar with timing marks and adjustment procedures, i recommend you buy the manual and follow the steps outlined, the illustrations are also a big help.
Good luck, i hope this helps.
Jul 17, 2011 | 2008 kawasaki ZZR1400
Need to know what the specs are for v2203-e head bolts torque
Do you mean a Kobuta v2203 e diesel engine? This looks to be in the Air Compressor section?
Anyhow, the specs for that are here: http://www.frontierpower.com/kubota/oldkubota.htm#Super3
Jan 12, 2011 | Air Tools & Compressors
Black and decker 18
i can only send the wiring by fax.
Jul 08, 2008 | Electrical Supplies
Garden Logo
308 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
