Question about Samsung HC-R4755W 47" HDTV
Color is faded and not very bright and gets darker toward the edges
    Top Expert:
  • Samsung Master
  • 14,553 Answers
MODEL PICTURED IS REAR PROJECTION WITH PICTURE TUBES.
IF IT HAS NOT BEEN "SERVICED" FOR SOME TIME TRY THIS:
WITH SET UNPLUGGED REMOVE BACK COVER---LOOK UP AND LOCATE THE THREE LARGE ROUND BLACK LENS--they can be cleaned with either a lens cloth or a paper towel with glass cleaner sprayed on it.
They are the light source for your picture and if even moderately dusty will make picture duller and darker than it once was.
Cleaning, depending on how dusty a environment you have the set in, should be done once a year.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have any questions post a comment right here and I will assist you.
SD TECH
Posted on Aug 21, 2010
  • jsuprick Oct 06, 2010
    Just took one apart, the problem with this one is the cooling oil in one or more tubes needs replacing. To determine this, each tube had an expansion bag on the uphill side the tube lens. The bag(s) with yellow or brown oil in it need to be cleaned and replaced, it should be clear.
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
I have my settings on sports for a high contrast and nice bright sharp color and in the last 2 weeks the color has gotten darker. Like the contrast is slowly starting to fade away. On blu ray movies the...
you have to check preset picture mode if still not good then reset setting in setup mode.after that your picture become good. if problem still then there is problem with LCD panel.
Oct 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
Why the color fade towards the edge?
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper pieces is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer for settings to ensure everything is order.
lastly, check hp's printer trouble shooting web site for more information. or the printer head might had a fleck of dirt on it, run a print test
good luck.
Apr 29, 2010 | HP LaserJet 1600 Printer
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung HC-R4755W 47" HDTV Logo
289 people viewed this question
Jerry Greenberg
Jerry Greenberg
