Question about Emerson MW8102SS 1100 Watts Microwave Oven
My microwave turns on when you press start makes a noise that sounds like what happens when you put tin foil in it and it does not heat anything up everything else on it works fan light just wont cook anything what is the problem
  • Emerson Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 22, 2010
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I was cooking frozen vegetables and frozen veggie buffalo wings in the microwave when I received sparking with a hissing noise and there was smoke in it? Is it safe to use
could be fine, did any of the food have any tin foil on it? I would try it without anything inside of it, if it sparks, get rid of it, now!
Dec 29, 2010 | Emerson 025806092806 Microwave Oven
Does using tin foil in microwave ruin unit or can it be used again safely?
its a bad idear,,,i never put any tin foil in mine, it scaters the microwaves around and sme times causes sparks as well,
Nov 28, 2010 | Microwave Ovens
We put a plastic jar with a very small piece of foil on the rim and the microwave started to smoke. it might have run 30 seconds before we noticed it making a funny noise. it is a 1200 watt inverter
Hello Dwight,
You may have damaged the microwave. Since the oven cavity is a tuned cavity, introducing metal into it can wreck havoc on the magnetron (microwave generator itself).
Did you happen to notice if the smoke was from the plastic jar (plastic heating up from the high temp of the foil ring), or if it was the actual microwave smoking (and not blowing smoke out of the oven cavity from the plastic jar)?
Sep 14, 2010 | Panasonic MCM INVERTER
After a few seconds my microwave makes a crackling
check for scraps of foil, wire ties any type of metal or tin,or aluminumif not any of that, ur looking at a componet problem
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Will tin foil in the microwave ruin it completely? The microwave turned off after my son mircowaved a potato wrapped in tin foil.
You should always put a spoon in a cup of liquid that you heat in a microwave oven.
The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble.
1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight.
One might ask the question how old is your child and should they be using such a machine unsupervised!
Nov 05, 2009 | Microwave Ovens
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Microwave stopped heating
More than likely the magnatron has failed,it is the heating source for microwave and usualy has 5 year warranty so it would be worth calling company about this. They will hve service company repair at no cost to you.
Apr 21, 2009 | Microwave Ovens
Jvm1440bd Microwave
I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
Jan 08, 2007 | GE JVM1410 Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
90 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
