Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 natural gas to propane conversion my instructions say to remove the plastic protected hex-nut cap I don't see that anywhere ,just a brass cap with a plastic plunger to compress the spring what am I missing here
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
Convert GE XL44 from LP to gas
replace original orifices and adjust regulator to natural gas
Dec 30, 2009 | Kitchen Ranges
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE44XL propane to gas
contact the gas company and they will install the kit needed for the conversion. I hope this helps.
Jan 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
LG gas dryer to convert in propane
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
May 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Convert from natural gas to propane
Step 6:
To prepare the new unit for LP gas you need to adjust several items. First you will need to replace the range orifices or spuds. These are individually sized with marks and colors.
remove_spud-s.jpg Step 7:
Using a nut driver, loosen the old spud and replace with the new one.The trick to keeping from dropping the spud down inside the range is to use a small piece of aluminum foil between the driver and the spud. This should provide enough "grip".
If you do drop one down inside, you'll need torx wrenches to disassemble the burner units and get inside.
orafice_setting-s.jpg Step 8:
tighten_orifica_on_broiler-s.jpgThe oven orifices need to be adjusted. Using an open-end wrench, tighten down the brass fitting on the oven burner valve.
Step 9:
There may be two orifices, one for the broiler and one for the main oven burner.
reverse_for_lp.2.jpg Step 10:
You will need to reverse the plastic pin in the regulator underneath the range. Remove the hex nut and flip the plastic pin and reassemble the nut.
Do not over tighten!
The last step is to open the air shutters on each burner as per directions included with the range conversion kit.
Nov 07, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
288 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
