Question about Frigidaire FTF530FS Front Load Washer
I have had my washing machine for 3 yrs. lately it doesnt always high speed spin. it doesnt seem to change whether the load is small or larger. sometimes it does sometimes it doesnt.
    President:
  • 2,702 Answers
First have a look at the motor brushes they may need changing for a new set,,,if there good,,,its likely to be the programer at fault
Posted on Aug 21, 2010
Kenmore washer
You can check the belt. It's posible to be worn out.
All the best !
Oct 02, 2017 | Kenmore Washing Machines
Machines 510
these machines can get seized bearings, which can stop the bowl from turning at full speed. probably the motor after this.the clutch should affect full spin speed only if it's worn. this fault can be a timer issue also.
Nov 17, 2013 | Hoover Washing Machines
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Does not always spin
How old and is it on all loads? How fast to stop the machine when you lift the lid? Can you stop the tub while spinning, careful on this one?
Oct 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire FTF530FS Front Load Washer Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
