Question about Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHU 4320 has suddenly quit draining. I have cleaned out everything and no kinks in hoses. My drains are not clogged. I have tried the suggestions in the manual and no luck. also my glasses are cloudy. Any ideas? Thanks
  • Bosch Expert
  • 414 Answers
Check your salt container is full and the cap is on securely and there are no cracks in lid. Check the rinse aid is full. Check that the holes in the spray arms are not blocked with food, plastic etc. or if you have a deodoriser hanging on the top basket that it is not obstructing the rotation of the spray arm. Try running a d/w cleaner through the machine.
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. If the d/w is connected via a sealed spigot to the sink, remove the grey hose and unscrew the spigot adaptor from the sink and ensure there are no blockages.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
ps I appreciate the link is not for your model but the part placing should be the same
Hope this helps, please leave feedback or add comment if this helps or you require further assistance.
Posted on Aug 21, 2010
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My dishwasher won't drain
Hi
Daniel
Dec 18, 2010 | Bosch SHE4AM02UC 24 in. Built-in...
Bosch SGS43E02 will not drain - otherwise seems fine Any help? Thanks
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 07, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Washer won't drain. Water remains in bottom of washer after cycled is complete.
Hi
Thanks
Rylee
Oct 06, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 21, 2010 | Bosch Dishwashers
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Daniel
Jul 22, 2010 | Bosch Dishwashers
Does not drain water out at end of cycle, I have tried cleaning out all the screens,have opened the impeller cover and checked that the impeller is clean and free. When I put together, it runs for 2 or 3...
Hi
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
Dirty water isn't draining
Hi
Thanks
Rylee
Dec 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
It wont drain
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher won't drain. Floods out onto the floor. How do I clear the drain, I have already cleaned out the filter
Hi
Thanks
Rylee
Nov 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
252 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
