Question about Microsoft Windows 2000 Professional for PC
Error message comes up when I turn my computer on
Error loading C:Progra~1MYWEBS~1arbinMWSBAR.DLL
what does this mean and how can I fix this?
Thanks
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
First, "mwsbar.dll" is associated with the "My Web Search" toolbar which is downloaded and installed with several different free products. The first step is simple: go to Control Panel, Add or Remove Programs... and look for and uninstall "My Web Search Bar". It can actually be present under several different names, so look for any of the other items listed here.
Even though My Web Search is not spyware, it's apparently flagged by some anti-spyware utilities. So my next recommendation is, of course, to make sure you're running a good, up-to-date spyware scan.
Hope this helps.
Posted on May 03, 2008
How do I fix this error: Error loading C:PROGRA~1MYWEBS~1ar.binM3PLUGIN.DLL The specified module could not be found.
You have picked up the horrible program My web Search. You need to get this off your computer asap. Restart your computer in Safe Mode and then go to Control Panel >> Add/Remove programs and find My Web Search and uninstall it. Immediately run your security scans while still in Safe Mode. Restart your computer after doing all this and it will return to normal mode.
Nov 30, 2009 | Intel Motherboard
@ start error message C:\PROGRA~1MYWEBS~1\bar\6.bin\M3PLUGIN.DLL
It seems this dll files is set to load at start up and would actually seem a virus of some sort, nevertheless, this file is not necessary and should be removed from the system and is already removed, all you need to do is disable this file to load at start up follow these steps:
Start>>>Run>>type msconfig>>go to the start up tab and look for the entry that is loading the dll file on startup>>uncheck the entry click apply then click close, restart the pc and the error message should not pop-up anymore.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 31, 2009 | Microsoft Windows XP Professional for PC
Error loading c;progra~1mywebs~1ar.binm3plugin.dll
Ok, you have downloaded a bug to your computer (it says its a toolbar for IE)
Go to Control Panel > Add & Remove Programs > Look for MyWebSearch and uninstall it.
download combofix.exe and run this, turn off your antivirus too
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
You can also remove it by running Spybot Search & Destroy.
Nov 09, 2009 | Intel Motherboard
Cannot load any software
That is a piece of spyware you need to remove. You will need to load in safe mode to fix it.
Jun 26, 2009 | Toshiba Satellite 2410-S203 Notebook
D:PROGRA~1MYWEBS~1\bar\1.binM3PLUGIN.DLL
Just reinstall the Microsoft Windows XP Professional! If u are running pentium 4 or later, just use Windows Vista Home Premium !
Jan 15, 2009 | Microsoft Windows XP Professional
Error loading c:\progra~1\mywebs~1\bar\1.bin\m3plugin.dll
You have spyware infesting your computer, the mywebsearch browser helper object. Run either Adaware or Spybot Search & Destroy, either should get rid of it for you. If not, please post to this thread and I'll give you a link to manual removal.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Error: C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
Hi
Hey dear its a virus, luckily your antivirus has already removed it from your pc. one trace is remains in registry which will try to load it on startup.
Ok, do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it.
Ok thats all. restart your system .
Sep 17, 2008 | Microsoft Windows XP Home Edition
Error loading c:progra~1\my webs~1 bar\2.bin\m3 plugin dll
http://www.dll-files.com/dllindex/m3plugin.zip?0VEdSCYIhX
click on that link save it to your desktop and then extract it to the following error location
C:Progra~1MyWEBS~1ar.binM3PLUGIN.DLL
Sep 17, 2008 | Computers & Internet
Window proffectional 2000
This message occurs when a "run key" still exists in the registry for an item that has been removed from your machine.
In this case, you would just "fix" it with HJT to remove the key from the registry.
If you still have Mywebsearch active, the first step would be to uninstall it via Add/Remove Programs.
Failing that, open the C:\PROGRAM FILES\MYWEBSEARCH folder and run the uninstaller manually. If no uninstaller exists, you could just delete the folder and clean registry remnants manually, to the extent desired - (most just remove the runkey and leave it at that).
Mar 19, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Windows 2000 Professional for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
