Question about Toshiba Televison & Video
What is the 4 digit sky remote control code for toshiba 32BV700B
Hi
Sky v8 remote code is 1065
Cheers
Steve
Posted on Oct 01, 2010
  • DiamondDesti Jan 03, 2011
    code is 0063
    I found it after 4 hours of trial and tribulation
  • moonstone227 Mar 12, 2011
    Well doneyo youu for your patience. I now have my Tv operating thanks to your persiverance - thank you.
2 Suggested Answers
SOURCE: Just purchased a Toshiba 32BV700B
try 1191
Posted on Sep 29, 2010
My toshiba 32bv700b is not responding to the remote control The remote appears to work and have even bought a new one
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Jul 24, 2015 | Toshiba Televison & Video
Program toshiba remote RC_3910 to sky remote need code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 04, 2014 | Televison & Video
Need a code for 37bv700b for sky remote number not on sky list
Hello
Toshiba has a lot of codes to check with Sky remote. They are:
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
536
581
216
253
063
746
726
508
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
OK.
Jul 21, 2011 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
I am looking for the remote code to pair my toshiba 40xf355d tv to my sky hd remote. Can you help?
0156 works for me 3/1/2015
Turn on your Toshiba TV.
Press the TV button on your Sky remote control.
Hold the Select and RED buttons for several seconds until the LED blinks twice then release.
Press the TV button again
Enter the 4 digit brand code: 0156 - the LED will blink twice
Point the remote at the TV and press the Stand by button.
If the television goes into Stand By press the SELECT button to store this code.
If the TV does not go in to Stand by mode, press the TV button and repeat from step 6
Dec 14, 2010 | Toshiba Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
Televison & Video Logo
1,411 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
