Question about Oasis Dehumidifiers
The coil keeps iceing up - Oasis Dehumidifiers
    Problem Solver:
  • 4 Answers
Is the filter and coil clean? In high humidity the unit mat run too long and freeze. Try turning the humidistat a little lower
Posted on Aug 21, 2010
HI HAVE GOT A SWAN SH3010 DEHUMIDIFIER BUT THE COIL KEEPS FREEZING OVER WHAT AM I DOING WRONG?
Nothing.That's how it works. The coil gets cold. The moisture(water) in the air freezes to the coil. The coil then gets warm and the ice melts, dripping into the bucket or out the drain hose.
Jan 04, 2015 | Dehumidifiers
Zenith dehumidifier is freezing up on the front near the air intake.
check to see if the fan is working. low or no air flow will cause it to ice up. may have to remove the front to de-ice. turn the unit off and slowly pour warm water over the coils to thaw. the water should drain right into the bin. also good to clean any dust off of the coils to keep the air flow open.
Feb 27, 2014 | Zenith Dehumidifiers
Coil keeps freezing up. ie. coated with ice!
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jul 13, 2011 | Fedders A7DH45B2A Dehumidifier
3 year-old machine. Appears that the main refridgerant supply line to the coils ices up soon after you turn it on, starting near a small canister of some kind, then the ice makes it way across the...
Often times, a clogged filter will cause them to freeze up. Because, it's not getting enough air into the system to warm the coils. If you haven't cleaned the filter recently or regularly, that is more than likely the problem. Other than that, the ambient room temperature can play a role in it. If it's cooler than 41 degrees, the humidifier struggles. Same is true if it's over 93 degrees.
Hope this helps you solve the problem.
Mar 11, 2011 | Kenmore 54701 Dehumidifier
Does not generate water. The fan keeps on running. Forms ice on coils
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 06, 2010 | Danby DDR586R Dehumidifier
Have a wind chaser wdh running in my basement and it keeps icing
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Icing up on our dehumidifier
typically happens when there is a lot of dust in air. Try cleaning it VERY well, which would mean, shutting it for a few days, letting it melt and dry off, then not only vacuuming it, but then take an air gun (or Air in a can) and get the dust off the coils. Obviously if there is a filter clean it, or replace it.
Check for bent fins on the coil. Most of the newer ones (and yours should as well) have an auto defrost to help with that.
Good luck
Jun 25, 2009 | DeLonghi DE40P Dehumidifier
Dehumidifiers Logo
131 people viewed this question
Top Oasis Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you an Oasis Dehumidifier Expert? Answer questions, earn points and help others
