Question about Samsung HT-AS720ST Theater System
Hello my name eddy leiva like 1 year ago i bought a av surround reciever ac-r720 and like 3 month ago the subwoofer stop working its has power because you can hear when it turn on but you cant hear anything from it. its connected correctly please help!
  • 4 Answers
SOURCE: my samsung 40" lcd power problem
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
fathitkf
  • 1871 Answers
SOURCE: i cant recieve calls or make any calls from my cell phone
Hello:
You need to restore factory settings of your k800i .
your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
good luck .
Posted on Feb 03, 2010
  • 286 Answers
SOURCE: My Samsung HT-AS720ST (AV-R720) surround sound receiver started
The problem is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
Problem is now solved. Unit works perfectly. If you have never tried working with surface-mount ICs I would skip it if I were you. This IC has over 100 pins on it. However the part is available from Samsung. Print this comment and take it to your locat service centre along with your receiver. They should be able to repair the board unless they are wussies and cannot do surface-mount work.
Posted on Oct 21, 2010
  • 21 Answers
SOURCE: I cant get the surround sound to work after
Hi
You will have to assign the optical input to the input you are using, so for instance if you have plugged the optical cable into opt 1 on the onkyo reciever and wish to use the DVD input on the onkyo reciever, you need to go into the set of the onkyo to digital assignments or in/out assignments, dependent on the model, and select OPT1 for the DVD input. You can find out how to exactly do this in the onkyo's manual under 'digital assignments' or 'input assignments'.
Regards
TechSupp12
Posted on Dec 12, 2010
SOURCE: I own a Samsung AV Surround Receiver AV-R720. I
I was just looking for a service location online and found this site...I have the same problem as the last guy...!
Posted on Jan 11, 2011
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
My a102jamo surround sound speakers and working
Aug 31, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
I have a durabrand HT-3916 and the subwoofer stopped working. Any thoughts on what might be the problem?
Suggestions:
1.Power supply or inline fuse.
2. if no power light then it is the power supply.
3. bad AC cord.
Jul 05, 2011 | Durabrand 5.1 Surround Sound Computer...
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Samsung HT-AS720ST Theater System Logo
32 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
