Question about HP Compaq Presario V6000T Notebook
When I powered down and rebooted I got Windows Boot Manager Windows encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or faulty CD-rom drive that is failing. Make sure that removable storage is properly connected and then restart your computer. If you continue to receive this error message, contact the hardware manufacturer. Status : 0xc00000e9 Info: An unexpected I/O error has occurred
    Brigadier General:
  • 10,406 Answers
So, the disk ("hard", not "floppy") drive in your computer is very soon to be "dead".
Posted on Aug 21, 2010
4 Suggested Answers
  • 788 Answers
SOURCE: Windows boot manager-hardware failure
Try pressing F-8 and look for last known good working configuration.
If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
Posted on Sep 15, 2009
  • 24 Answers
SOURCE: my emachine250 has encountered a
This thread on the TechNet forum seems to have several options you can try to fix your PC's error
Posted on Apr 28, 2011
  • 343 Answers
SOURCE: Windows Boot Manager message: Windows encountered
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Posted on Jul 23, 2011
Hello, Im having a problem with my Dell INSPIRON 1750.
it's possible your hard drive has gone bad, that's what it sounds like
Aug 02, 2012 | Dell Inspiron Computers & Internet
My sistam is not restore ... WHY???
This error code usually points to an installation of windows that has been corrupted. I'm assuming that you have no USB flash drives plugged into the laptop when booting, if so, remove these and try a reboot.
Then try to boot to safe mode (f8)
If this fails, boot from the CD drive by setting the DC boot option as 1st boot in the bios, put the windows installtion CD in the drive and go through the install proceedure, selecting the REPAIR option.
If this fails, you will need to reinstall windows.
To recover any lost files, after reinstalling windows, download a utility such as recover my files and set it to a format recovery to get any lost files back.
Jun 21, 2012 | Samsung R530 22GHz Intel Core Duo...
As I was on a site. The computer froze. I rebooted it, which took a minute to do. When it came up, it displays a windows boot manager screen saying imwindiws has encountered a problem communicating with...
1. This is a virus that has embedded it self in the hard drive and has rendered the hard drive boot sector to a null state causing a corrupted boot up sector.
2. the only remedy here is to format the hard drive or to reinstall Windows on to a known good sector on the hard drive. This is not for a novice and take a few hours to complete
3. A new hard drive is needed here and reloading the Windows Operating system.
4. if this is a usb drive it could be that the electronics have malfunctioned and a new case with new electronic will have to be installed.
5. USB driveS have to be ejected properly or they will cause the electronics to fail.
6. in the task bar the drive is to be safely removed by the system to avoid data malfunction to the usb device.
Mar 09, 2011 | Computers & Internet
I have an hp mini 110 that was working fine. One day I went to start it and nothing happened. I removed and replaced the battery. Now I get a message that "windows encountered a problem...
First off you should have backups of all important data in case something like this happens....ok lecture over----now boot to SAFE-MODE (F8 @startup) and go to DEVICE MANAGER and see exactly which device is giving you the issue..I doubt that its the harddrive because at that point you already passed POST and you said WINDOWS encountered the problem with a device..so most likely it is a DRIVER issue (aka software code for all hardware devices)
Dec 26, 2010 | HP Mini 110-1037NR Netbook
I have a Toshiba Satellite A135-S2276 laptop running Windows Vista. The laptop was dropped from about 12 inches by my child. When I opened Explorer, it was acting funny, so I rebooted. The main Toshiba...
Windows is corrupted beyond repair, you need to reinstall it. For the recovery discs, call Toshiba at 800-457-7777. They will want to know the computer's serial number and a credit card number.
Sep 09, 2010 | Computers & Internet
When I powered down and rebooted I got Windows Boot Manager Windows encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage...
hmm seems a lil odd it appears that maybe your internal computer hard drive is failing or that its not properly connected if its happened recently with no internal computer changes then its definitely the hard drive failing on you
Apr 22, 2017 | HP Compaq Presario SR1110NX PC Desktop
Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Oct 02, 2009 | HP Compaq Presario V6000T Notebook
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Windows does not boot up
This is likely your hard drive - this could be a drive error - in which case your drive is likely lost (and the data on it) I'm afraid. A technician would check the cables to your drive are ok. In laptops you can usually take out the hard drive under the laptop. If you can, do this, clean the connectors and plug back in. If that doesn't work then I'm afraid it isnt good.
Apr 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP Compaq Presario V6000T Notebook Logo
452 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
