Question about Dell W5001C 50 in. Plasma HDTV
My dell 50" plasma tv had a blown 8amp fuse on the power board. When I replace it lights appers on other boards but whn I turn the tv on the fuse blows. Any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
Replace the power supply board.
Posted on Aug 23, 2010
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
Hi, i was given a NEC 50" plasma tv model #
What is the problem you faces with it now? If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 07, 2017 | NEC Televison & Video
My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 23, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
50' Plasma won't turn on. No power.
hi, i have the same unit and did the same as yours i open it up and it had a blown fuse on the main board there four fuses. mines had ones of the two fuses on the right lower corner of the main board blown out i replaced it and worked fine again.
Apr 19, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Went to turn on tv and nothing happened. not even the red light powered up. it worked just fine the night before and nothing is out of the norm. got any ideas? I've got power to the power strip. would the...
Tries unplug,replug an hour later.Still no power than.Ur power board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | Zenith Z50P3 50 in. Plasma TV
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
My 50" Plasma blew a 8amp fuse at the power supply. I replaced it, and the TV works again, buy why would this fuse have blown in the first place?
if the fuse was at the or near the AC plug chances are your got a power surge, if you did you got very lucky the fuse was there you might want to get a surge protector on the set ... But sometime you get just a defective fuse as long as the set is working I would not worry about it
Dec 07, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a LG PDP-42x30401 it has blown the 8Amp fuse at the primary power distrabution board what could be causing this
Is this the main input fuse on the A.C. line? If that is the case then your regulator or rectifier section is shorted on your power supply board. The part number for the board on a LG TV will sometimes vary by the model version number that is located on the side or the back of the TV. Please take a moment to rate my answer. Thanks...
Nov 23, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Dell W5001C 50 in. Plasma HDTV Logo
180 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
