Have tried all things written online. HP c8180 continues to give "ink system has failed. Unable to print. Refer to printer documentation . Error 0xc 19a0005 Turn power off, then on again" I have spent a few hours doing all things recommended.
  • robertand540 Aug 21, 2010
    ok.
    Thanks for your thoughts and expertiese.
    Spent the last hour cleaning off driver and reloading it and the following directions..
    When reconnected it came up with the same error came up on the Printer as before (when printer turns on it errors before I attempt to send print request on the new driver or old from computer.)
    These printers have touch screens (photosmart express) where you can request printing from photo cards plugged into them as well as the normal USB and wireless bluetooth and ethernet.
    Tried Part 2 ...unplugged the printer replugged it while pushing print photo...Unusual green screen on printer screen came up (12345) it functioned incorrectly (things whirred around but no printing or paper engagement) and when I restarted it again, it gave me the same error.
    So I am thinking it is not the driver on the computer causing the issue as we had hoped. Mainly because:
    a. your 2nd plan did not change or improve things and
    b. I get the same "ink system error" issue when I put a photo card in and try to print it.
    I am not sure if I can override any software on the printer device... if overriding the printer sotware on the printer is what you were helping me do, i do not understand how that would work.
    I read somewhere that air bubbles in the ink lines could cause this problem...i have added new ink cartridges and done things and to tried to push through test pages...only once did paper go through and at that time no ink was pushed through. I cannot see how to get the printer carriage out of the device like other .
    What is next?
    ok. Thanks for your thoughts and expertiese. Spent an last hour cleaning off driver and reloading it and the following directions.. When reconnected it came up with the same error came up on the Printer as before (when printer turns on it errors before I attempt to send print request on the new driver or old from computer.) These printers have touch screens (photosmart express) where you can request printing from photo cards plugged into them as well as the normal USB and wireless bluetooth and ethernet. Tried Part 2 ...unplugged the printer replugged it while pushing print photo...Unusual green screen on printer screen came up (12345) it functioned incorrectly (things whirred around but no printing or paper engagement) and when I restarted it again, it gave me the same error. So I am thinking it is not the driver on the computer causing the issue as we had hoped. Mainly because: a. your 2nd plan did not change or improve things and b. I get the same "ink system error" issue when I put a photo card in and try to print it. I am not sure if I can override any software on the printer device... if overriding the printer sotware on the printer is what you were helping me do, i do not understand how that would work. I read somewhere that air bubbles in the ink lines could cause this problem...i have added new ink cartridges and done things and to tried to push through test pages...only once did paper go through and at that time no ink was pushed through. I cannot see how to get the printer carriage out of the device like other . What is next?
  • 4,323 Answers
Hi
This error occurs due to a failed Ink System or due to a driver issue with the printer. To resolve the issue turn off the printer, disconnect it from computer and power. Now, remove the drivers for C8180 and restart the computer. After the restart connect the printer with the computer and try to print. If you get device not recognised or any such kind of error then disconnect the printer from the computer and install the drivers. Restart the computer again and connect the printer after restart.
If it doesn't work then unplug the printer, re-plug while pushing the "print photo" button at the same time. This may cause the printer to function incorrectly. If it functions differently or you are getting any other error then go to Control Panel-> printers and faxes and delete the printer. And then restart the computer and go the Control Panel-. add new hardware device wizard to find the printer. This will resolve the issue.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
  • 4,924 Answers
C8180 Ink System Failure
1. Unplug the power cord from the back of the HP All-in-One.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control pan
Posted on Aug 22, 2010
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
Jun 24, 2014 | United Stationers HP Photosmart C8180...
"Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0101 Turn power off, then on again."
The first problem is you have an ink jet consumer printer. Go to their support site and search that error code. That may help, but don't count on it. HP is notorious for selling defective products and have lost more than one class action suites. you can try these steps http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
But it could also be the error for when the ink resovors are full in the bottom of the machine. It will stop working by design then. If it were to over flow you would see where all that ink went you been buying, so they stop the machine before that happens. Best advice is take it to the nearest dumpster and deposit it inside it, and buy a laser printer. It was the best thing I ever did.
Jun 17, 2014 | HP Photosmart C6180 All-in-One Printer,...
Ink system has failed unable to print. Refer to printer documentation Error Oxc18a0206 printer error for HP C8180 All in one error.
Master Reset:
  • Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 15, 2010 | Office Equipment & Supplies
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP photo printer D7360 error message
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
All The Best: Pineworks
Jun 04, 2009 | HP Photosmart D7360 All-In-One InkJet...
Won't print
Ink system has failed. Unable to print. Refer to printer documentation. Error:Oxc18a0101
Mar 29, 2009 | HP Office Equipment & Supplies
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
PRINTER NOT ABLE TO PRINT
These error codes indicate that the product has an internal condition. Solution one: Reset the product Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 23, 2008 | HP Photosmart C8180 All-in-One InkJet...
181 people viewed this question
jasbo
jasbo
