Question about Dell Inspiron 6400 Notebook
Dell inspiron 1545; windows 7 os; error code 2000-0152; can't bring up desktop, f12 does not work. Any ideas how to fix? Do we have to replace the hard drive? Only 8 mos old.
cabanagj43
  • 225 Answers
SOURCE: dell inspiron 1545 problem on installation,problem
1. boot to cd/dvd rom using the dell resource drivers utilities. you need to test the dvd drive if it is working, if yes, we might have 2 problems it might be the dvd installer or the hdd. run a test for the hdd to isolate the issue or you can try to run the installer to a diff computer to test if dvd installer is not faulty.
Posted on Oct 08, 2009
  • 76 Answers
SOURCE: i have a dell inspiron 1545 laptop and audio isn't working
1. Go to support website
http://supportapj.dell.com/support/index.aspx?c=au&l=en&s=gen
2. Click on Drivers and Downloads.
3. Click on Choose by Service Tag
4. Enter you Service Tag
5. Download the Audio Drivers and Install it after the download
Posted on Oct 16, 2009
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Posted on Apr 25, 2010
  • 151 Answers
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
Posted on Apr 28, 2010
nonontech
  • 4737 Answers
SOURCE: How do you change the
The easiest way to change wallpaper/desktop background is open the picture/photo, right-click and "Set as desktop background".
You can do it from the personalize options available in display settings. Right-click on the desktop, select "personalize" and click "Desktop Background" from the available lists and browse the picture/photo you want to set as desktop background.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 21, 2010
How to fix error code 4400:011A on dell inspiron 560 window 7 home premium
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/0f00-133c-error-code-no-suitable-disk-or-media-is/66dcc559-bd4f-4b70-a39e-0dfd7669d596
Mar 24, 2013 | Dell Computers & Internet
Dell Inspiron 1545 red processor:Pentium(R) Dual-core CPU T4400 @2.20GHz is error code 2000-0221, how to solve this problem?
this is a bios level error, you should still be able to run the system. this code is something you get when you hit F12 and run the diagnostics? or is this a blue screen error? you are probably going to need to boot to F2 (setup) then hit "Alt e" Alt F then Alt B the system will beep on the alt f but that's ok once this is done hit esc, save changes and reboot and see if you still get the error
Feb 10, 2013 | Dell Red 15.6" Inspiron 1545 Laptop PC...
My hard drive in my 1545 inspiron is shot. I am getting a code of 2000-0146, a harddrive error. should I reinststall the OS and start over or do I need to buy a new harddrive. I can't even run safe...
If you can get to your BIOS settings, change the hard drive settings from SATA to AHCI SATA and see if does anything for you. If not, then the hard drive needs to be replaced. Any 2.5" SATA drive will work. You will need to re install your OS, drivers, and all when or if a new drive is installed. If you have a back up CD it shouldn't be hard, but you are going to loose any data that you had saved.
Aug 10, 2011 | Dell Inspiron 1545 Notebook
My brother has a Dell Inspiron 1545, running Windows 7, that he got this past Christmas. It will no longer boot. I get past the Dell logo to a blank screen, but in the top left hand corner is a blinking...
Usually you would use the OS installation disk to get into restore mode (be careful, you don't want to accidentally delete everything by reinstalling the OS).
It should still be under warranty!!! So if I were you, and if you need a little hand holding, call Dell Customer support at 1-877-293-1197. Have your model number, serial code (usually somewhere on the bottom of the laptop), and setup disks for that computer handy before you call them.
They may walk you through a few procedures to try first before resorting to restore mode, but just be patient with them.
Hope this help you. Let me know how it turns out.
Jun 15, 2011 | Dell Inspiron 1545 Notebook
I have dell inspiron 1545 ultimate & window 7 it was before vista.Now blue tooth is not working please help me out.
Upgrading your laptop OS from Vista to Win 7, you have to reinstall your Bluetooth drivers for Win 7 OS(ie x86bit or x64bit) for the Bluetooth to function properly.
Dell Inspiron 1545 download @ http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=
Under "Network" -> Select your correct Bluetooth drivers versions for your OS Win 7 (i.e. x86bit or x64bit) to install.
Hope it helps.
May 21, 2011 | Computers & Internet
Web cam of inspiron 1545 is not working with windows 7 what shall i do?
Go to www.dell.com and at the bottom of teh page select "Drivers & Downloads" under "Support".
Once in the support section select "Support for home users"
In the next page select laptops > Inspiron laptops > Inpsiron 1545
Then it will ask for an OS, select the windows 7 and when you find your driver it will give both 32 bit and 64 bit versions. This should fix your issue.
Feb 04, 2011 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 6400 Notebook Logo
1,663 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
