I have an Amana Model GUC-C 90 Hi-efficiency furnace that we installed in 1992. It has a central air unit as well. On Friday we tried to turn the air on and nothing will work. I have replaced switches in the air unit in the past but this time there is no clicking, I can't turn the circulation fan on for the unit, the heater unit will not turn on. I have power at the breaker, and on the unit itself there is a on/off switch with a round screw in fuse, that fuse is good and I have power there. What could be the problem
  • harless Aug 21, 2010
    We don't have a 110 volt unit for our air. This is a central air system on a 220 breaker. As I indicated, non of the units are working, central air, furnace, or the blower for the furnace/central air. There is no burnt wiring, in the past when I had a relay go bad on the air unit I could hear the central air clicking, trying to work but the relay was bad then. Today I have nothing, no sounds, my breakers are fine, what are your thoughts?
  • 905 Answers
Your control transformer may have quit on you, or your thermostat may have gone out. The transformer is what supplies the current for the hvac system. The thermostat just controls what relays are energized. Since you have a problem with both the heating and cooling modes, that is indicating that your control voltage is gone, or is inadequate.
If you have a multimeter, check the output of the transformer, it should be about 24vac.
Posted on Aug 22, 2010
    Genius:
  • 1,478 Answers
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Thermostat Compressor Overload and/or relay Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
Posted on Aug 21, 2010
Heat pump is not kicking in no heat at 42 degree outdoor temp
check the wirings.the coils and also the heating element.also check the heating temprature.
also check the power outlet.
connect some where else.
and try to restart it again after five minites.after you unplug the device from the electric outlet.
Oct 10, 2008 | Amana PTH123B35AE Air Conditioner
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
Amana furnace not blowing hot air
My heating system is running so well because I have Amana furnace.
Nov 09, 2012 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Dec 31, 2009 | Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
