Question about Car Audio & Video
I HAVE A 15' KICKER L7 2 OHM WITH A DIAMOND AUDIO 2 CHANNEL BUT AM ONLY USING 1. HOW DO I WIRE THE VOICE COILS
  • 88 Answers
Hi so you have to connect your minus point of your speaker to the positve channel 1 amplifier output, after you connect the positive channel 2 output amplifier to the first coil connection (no polarised) and the second coil connection to your positive point of your speaker, this solution if you can bridge your amplifier to one channel output.
if you can't bridge your amplifier, you have to connect your minus point of your speaker to the negative channel 1 amplifier output, after you connect the positive channel 1 output amplifier to the first coil connection (no polarised) and the second coil connection to your positive point of your speaker
I hope this helps
Please rate accordingly
Thank You
sserpentio
Posted on May 03, 2008
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
Hey i have a 15"
The problem is probably the way you have them wired, but could be a couple of things.
A few things to think about.
1. Is your amplifier one or 2 channel. If it's one channel, it must be 2 ohm stable.
2. Are the gains on your amp turned up. This is the little knob next to the RCA input.
3. If your sub is a dual 4 ohm voice coil, you need to wire it to a 2 ohm load. Make sure the positive of the source is wired to the positive of both voice coils and the negative of the source is wired to the negative of both voice coils. This is what is called a parallel set up. If you wired from the source to one voice coil and daisy chained to the next, you probably have it in series, which creates a 8 ohm load. Which mean more resistance, less efficiency, and less sound.
4. Make sure the power wire to your amp is appropriate. A 50-65 amp load up to 22 feet in distance is good for a 4 guage wire. Anything bigger than that will need 0 guage.
5. Make sure your ground is good. If you know how to use a multimeter, check it. Always use the same guage wire as the power wire.
Hope this helps
Aug 19, 2011 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
How do you hook up the speaker wire to the ab sub out and what is the best way to hook them up at what ohm
Not sure what you mean by AB but being that this is a monoblock or 1 channel amplifier you can only hook it up 1 way. Verify the polarity from your speaker box. + to + and - to -. As far as your impedance is concerned this amp is stable to 1.5 ohms but for this case we will assume you have two 4 ohm subwoofers. When you parallel these together you will have a total effective load of 2 ohms on the amplifier. This is a stable operating impedance for the amp.
Other impedance options are:
two 8 ohm speakers = 4 ohm load
three 8 ohm speakers = 2.66 ohms
If you have dual voice coil subwoofers then parallel the coils on each sub + to + and - to -. Depending on the impedance of each sub you may then have to wire the individual subwoofers in series. Here is an example.
2 dual voice coils with 4 ohm taps
Each subwoofer with the coils in parallel would be a 2 ohm load if you were to then parallel the two subwoofers together you would have 1 ohm total load on your amp. This is BAD for your amp. Your option is to run the subwoofers in series.
To run the speakers in series is simple. The + from one speaker and the - from the other will be connected to the amp. The other + and - from the speakers will be connected together.
Here is a wiring diagram from kicker.
http://www.kicker.com/dvc_wiring
Jun 11, 2011 | Jl Audio Slash 500/1 Car Audio Amplifier
I have 2 kicker cvr15 4 ohm duel voice coil speakers how do i wire them to a kicker zx1000 amp??????????
The ZX1000 is a two ohm stable amplifier, so this means that you have to connect your two voice coils in series to give you around 8 ohms impedance per speaker, then connect your two speakers in parallel to give you 4 ohms impedance on the single mono channel on the amplifier. I recommend you connect it up in the following manner:
Apr 06, 2011 | Kicker Car Audio & Video
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
How do i hook up kicker solo baric in the box
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Nov 10, 2009 | Kicker CVR12 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
112 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
