Question about Sharp R-1481B Microwave Oven
I have a SHArp microwave model #R-1481. it stopped working last week. It turns on and rotates inside but sounds differnt and has a smell as it is on and is not heating anything up. Its 10yrs old I believe. Is it worth fixing or even fixable?
  • Sharp Master
  • 9,098 Answers
We have the service manual for this model and have uploaded it for you here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can order Sharp from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Aug 23, 2010
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Jan 19, 2010 | Sharp R-1480 Microwave Oven
Microwave not working-Sharp 798 M,oven Grill ok
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 25, 2009 | Bosch HME9760 Microwave Oven
Sharp Carousel R-1481 Turntable
It may very well have have damaged the turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On many Sharp models, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Be sure if you cook an egg that you puncture the shell first so it can breathe.
Mar 01, 2009 | Microwave Ovens
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Work light and night light do not work on Sharp Carosel R-1481
> Work light and night light do not work on Sharp...
Thanks for giving us the model number.
We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 22, 2008 | Sharp R-510HW Microwave Oven
Sharp r-1481 950 Watt microwave oven problen
Found the answer by calling a Sharp technician and they said it was the magnetron tube, which is not worth fixing :( Thought I'd pass this on to anyone that has yet to find out.
Oct 15, 2008 | Sharp R-1481B Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Turn table has stopped working in sharp r-930cs
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Sharp Carosel R-1481 (no B) & 950 Watts
All MW has a fuse inside to protect the circuit board
Try to replace the fuse
May 10, 2008 | Sharp R-1481B Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Sharp R-1481B Microwave Oven Logo
265 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
