Question about Samsung Computers & Internet
The blue light around the power button is doing a slow blink, the pc is up and there is no picture on the monitor.
    Brigadier General:
  • 10,406 Answers
The computer is "sleeping", in power-saving mode.
Touch any key, or wiggle the mouse, to awaken it.
Or, touch the on/off button, to awaken it.
Posted on Aug 21, 2010
I have a hp w2207 flat screen monitor. when turning power on, power blue light blinking and no picture. what can I check or look for to find and fix the problem?
That blue blinking light could be the fact that there is not a signal from the PC to the monitor itself. You could have lost your video card, corrupt driver for video card or monitor. If you have a PC with separate video card and a mother board video output, try switching to the one you are not using and rebooting the PC
Jun 12, 2014 | HP Computers & Internet
Simply blink red light in front or power led light ,no display anything .power on button is on blink red
Try to do a Hard Reset. Disconnect all peripherals connected from the unit (power adapter, monitor, keyboard, etc) then press and hold the power button for around 15 seconds. Plug everything back then power the PC on.
Hope this help. Goodluck!
Mar 28, 2011 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Jun 28, 2009 | Gateway FPD2185W 21 in. LCD Television
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Screen is blank.
Could have blown some capacitors inside the monitor.
I just fixed one today that had no power, the blue ring around the power button didn't even light up when plugged in.
I open it and found 3 bulgingcapacitors on the power/inverter board.
They were all 25V 470uF rated capacitors.
Went to radioshack and found 2 35V 470uf, got them at $1.29 each, then I found 1 50V 470uF out of a dc car power adapter for an ipod, it was as close as I could find.
Replaced the 3 broken/bulging ones with the new/salvaged ones, put it back together, plugged it in and the blue light came on when I pushed the power button.
Plugged it in to my laptop with vga cable, and it works great.
Oct 24, 2008 | Samsung SyncMaster 932B LCD Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
