Question about Lincoln Electric Century Portable Plasma Cutter - 25 Amp # 82021
I have a Lincoln Handy core welder of 130amps. It welds on "Low" but not on "High".
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: Where can I get a gas diffuser for a Lincoln
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Posted on Jun 14, 2011
Wire feed have erratic speed when welding.
adjust your speed either up or down to match the amps required to weld
Jun 08, 2015 | Lincoln Electric Handy MIG K21851 Welder
Fire power 160 heat range will not go low enough to weld thin material.
You need a smaller welder. Pick up a nice 110 unit that has at least 4 power settings. I have a lincoln 95 amp that will weld body panels on low and 1/2" on high.
Oct 17, 2013 | Firepower Welding Tools
How much does this welder cost?
Hi:
That welder in new conditions should cost about 350.00 dollars. Used probably just 120.00.
Oct 17, 2011 | Firepower Flux Core Wire Feed Welder 88...
Hi I have a Lincoln Handy Mig I am running 0.30 wire welding a roll cage on a race car the welder keeps overheating {light keeps coming on} wont weld just sputters keeps kicking the breaker {20 amp}...
check to see if the cooling fan is working. put a box fan behind the welder so it will blow threw the vents on the rear, or better yet remove the side cover and let the fan blow into the side of the welder.if this works replace the cooling can......GOOD LUCK
Jan 29, 2011 | Lincoln Welding Tools
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
My lincoln 140 welds fine on a low setting but when im welding on a high setting the spark starts out strong but seems to fizzle down and it does not burn in good. Please help MIKE
You may be exceding the duty cycle of your welder
Check your operstors manual to see how long you can weld at higher amps before giving the welder a chance to cool down
Oct 18, 2010 | Miller matic 140 Mig Welding Package W/As...
Welder will only weld for about three inches on high
If it won't push wire through gun you might need to tighten wire rollers, or check the liner for bad spots.
May 13, 2010 | Century 80GS Flux - Cored Wire Feed Welder
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
I have a Lincoln hady core wire fed welder, broken handle/trigger
if you call this number for Lincoln service they can fax or mail you that schmatic 1-216-481-8100
Aug 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln mig pac-100 low heat on highest setting.won't weld 20 ga.
if you are using flux core that might be why, flux core burns hotter, try using 75/25 or more argon than co2, as your gas, the gas will keep it a little cooler, keep your amps down and match the wire speed to the amps, which would be slower wire speed
Apr 15, 2009 | Lincoln Welding Tools
Lincoln Electric  Century Portable Plasma Cutter - 25 Amp # 82021 Logo
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
