Question about JVC AV-27230 27" TV
The sound and everything works great but the picture is just a thin line across the middle of the screen.
    Top Expert:
  • JVC Master
  • 14,553 Answers
This is a somewhat older set but it is a common problem and usually easy to fix.
Set uses a vertical output IC chip---7-13 pins and it is black and fairly small and will have number like LA7838 etc on the front of it (most LA series chips are for vertical. It is attached with a screw to a small metal plate to keep it cool (called a heat sink).
9 out of ten times the problem is the solder connections on the bottom of the board where it is soldered in have come loose from heat and age.
Once the board is out--10 minute job, I have done hundreds of them in my career.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a comment here and I will assist you.
SD TECH
Posted on Aug 21, 2010
  • kycsoccer2 Aug 23, 2010
    I've got the back off of my tv. I've found two chips that are mounted like you mentioned. However neither of them have the number you gave. One has LA7830 and the other LA4446. But when I look at the bottom of the board it doesn't look like either one is soldered in. It looks like they're just pushed into the board. Any suggestions would be appreciated.
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Thin blue lines across the screen.6or 8 of them 3 or 4 inches apart. everything else works great still perfect picture
You need to turn down the Blue Screen Drive control a notch, Blue tube has built up higher then R/G over Driving.
Sep 27, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
JVC AV-27230 27" TV Logo
57 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
