Question about Olevia LT37HVS 37 in. LCD HDTV
Help!! im housesitting and i switched of the tv from the mains before bed.When i turned it back on,its flashing "not programmed'' on the screen. Have i just wiped out the channels?
  • 132 Answers
There are so many variables about how the TV is hooked up. It could be hooked straight up to cable or a cable box, satellite receiver,or antenna. The point is it's not hard to reprogram if you know how it's hooked up. If you did wipe out the channels it should not be a big deal to set them back up.
Posted on Aug 21, 2010
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
Hi. I have a clarity hd tv I switched it off to go to bed and now when we switch it on there is sound but no picture it remains black. It does flash sometimes when u switch it on. Cam Anyone help?
It could be many things, how ever it sounds like you back light inverter board is failing or not getting enough power. What is your model?
You should start with checking your power supply, then test the inverter and main board
check here for more info
Power supply repair / test basic info
Jun 07, 2012 | Televison & Video
I am at a hotel right now and they have an LG tv and remote. My friends were playing there xbox360 on it but now they went to bed and now im trying to turn it to the tv but its not working and its stuck on...
You need to find a way to change the input back to TV. There may be an "INPUT" button on the TV itself, and/or a button on the remote. Use either to scroll through the options back to "TV".
Jun 11, 2011 | Televison & Video
I have a philips big screen tv model# 60P8342A and when I turn it on I can hear the sizzeling noise from when a tv is turned on but the screen is all black. What may be wrong with it and how can I fix it?
Do you mean sizzling from a certain area, like where the on off switch or mains input socket is, if so may be nothing more than a solder connection, If you know someone good with soldering , but be warned disconnect from mains and be careful, had a sizzling problem recently , turned out to be bed connection on mains socket.
pete
Nov 15, 2010 | Philips 42PF9431D/37 TV
Hi, i have a PS3 60G, turned it on, was working fine, played around with the sidplay to HDMI and themes, then the picture was destorted, switched off at main power switch on back, switched it back on, my...
You have it on the wrong TV setting you need to work out how to get to the tv setting BLIND then change it back to default!! I have had same problem wioth a friends but managed to change it without the screen back to default and now its ok.
Aug 13, 2010 | Video Game Consoles & Games
Help!!!!! I'm housesitting and cannot get the Fujitsu flatscreen to turn on. I've changed the remote batteries, but the red standby button the the left bottom of the TV screen keeps blinking. Can you help...
1. Try using the on/off switch that is on the TV itself and use the other buttons on the TV for sound and channel etc.
2. You might need to try a replacement remote.
3. On some remotes you need to press the "TV" button and, then, the power switch on the remote.
Oct 30, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
Olevia LT37HVS 37 in. LCD HDTV Logo
215 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
