Question about Sony VAIO CR320E/L T7250 2.0G 2GB 250GB DVDRW 14.1-WXGA XBE WVHP BLUE PC Notebook
How do u take the laptop apart to get to the video cable i removed all the screws and it wants to come apart i but it stuck like its glued in the middle can u help me out
  • cdfigueroa83 Aug 21, 2010
    so i have to remove the ribbon cables is there anything else that could be holding it dow i removed the screws that where under the keyboard wat els could it be ?
    Brigadier General:
  • 10,406 Answers
Can you gently lift the keyboard out (it probably has a ribbon-cable that needs to be gently separated from the motherboard), to expose some more screws????
Posted on Aug 21, 2010
  • ikkenom Aug 22, 2010
    Have you removed the battery? Did it expose more screws?
    I've seen laptops with tiny rubber cylinders (like a pencil eraser) that need to be removed to expose more screws, in recessed holes.
  • cdfigueroa83 Aug 22, 2010
    yes i removed the battery and i took those screws off also but its like something in the middle holding it and i dont wanna pull it apart. ill look for these rubber cylinders
How to check lcd flex video cable
Take the LCD Screen apart. The cable is on the back of the LCD and attaches at the top. To take the lcd screen apart remove the plastic strip that is around the lcd screen. There are screws under the rubber bumpers on the plastic strip. Once you remove the screws under the rubber bumpers, then the plastic strip can be removed. Then you'll be able to get to the screws on the side of the brackets holding the lcd screen.
Apr 03, 2012 | Computers & Internet
Cant remove screen seems glued on hp pavillion dv5 1007
ummm, i'd doubt that it is glued unless you had the screen repair previously by a shoddy repair shop. First of all normally the screens are held in place by screws that are hidden by little rubber bumper covers or some type of covering on the plastic that is around the screen. Use a safety pin or small flat head screwdriver to remove the covers and expose the screws. Then use a phillips head screw driver to remove the screws. Once all the screws are removed use your fingers to slide along the inside of the plastic around the screen and pry it loose from the screen.
Mar 10, 2012 | Computers & Internet
Hi I cracked the screen on my toshiba Satellitle L670-10N and have ordered and received a replacement. However, when trying to remove the broken screen, I cannot unscrew the screw on the bottom of the...
The screen portion of the laptop should be removed from the keyboard portion. There should be screws in the back of the laptop, or under a removable plastic piece directly about the keyboard. This will have to come apart anyway, because you have to remove the video cable from the mother board to replae the screen anyway.
Mar 21, 2011 | Toshiba Satellite L670D-ST2N03 Laptop...
Replace laptop screen
STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen assembly.
STEP 6.:-Separate LCD screen assembly from the display cover.
STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter board.
STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Hi I removed all the screws, and took apart my Toshiba Satellite M35X-S149 in order to resolder the power supply to the motherboard, however with everything out, the motherboard won't come out of the...
If you do not have a disassembly manual, here is one to go back and track your steps.....There may be other connectors you have not detached. Check carefully, screws aren't the only things holding the mobo in place. I think the M35 uses special nuts on the VGA port, these have to be removed for the motherboard to release....There appears to be one screw holding the system board to the lower case, with the board facing up, look in the middle and toward the top right edge of the board, there is a screw along the right edge. 2nd hole down, remove that screw and lift the right side of the board. Make sure all the wire and flat cable connections have been removed.
http://tim.id.au/laptops/toshiba/satellite%20m30-35.pdf
Nov 07, 2009 | Toshiba Satellite M35X-S149 PC Notebook
Funky screen on Toshiba A200 laptop
Either its a failing video card or failing LCD and in either case it will be several hundred dollars just for the part.
Most non-gaming laptops have integrated video built-in to the motherboard.
If you have never taken apart a laptop I would strongly recommend against it as you will be dealing with about 80 screws, parts that are taped, glued, clipped together.
If you do decide to the manufacturers generally have a how to guide and taking apart their laptops.
For my own benefit when I repair laptops I lay out sever pieces of paper and label them like back of laptop, front, under keyboard, ect to keep track of screws since size does matter :) when it comes to the screws.
Hope this helps
Nov 01, 2009 | Toshiba Satellite A200-0ET00X Notebook
My t-mobile behold touch screen stopped working and I need to fix it. How do I do that?
my phone did the same thing...if you are out of warranty you can fix it yourself, you just need to get a new "touch screen digitizer." you can order them on ebay for around 10 dollars, they usually even come with a little screw driver and seperator, if you are comfortable taking apart the phone its pretty easy and strait foward. 6 really small phillips screws on the back then it opens up, lift gently on the center of the latch on the back the phone to get to the last 2 screws, it'll slide down. The guts to the phone is held in by small clips all over so be carefull or you'll break them. Just pry them back carefully. As for the digitizer screen it's basically glued on the front. The only reason you gotta take the phone apart is for the small flat data cable attached from the screen to the inside. Gently lift up the black piece of plastic and pull the old cable out the slot, remove the screen(glued in) and work backwards from here......... it's not too bad...
Jul 16, 2009 | VK Mobile VK2020 Cellular Phone
How to take apart old, excellent running laptop for maintainence
When you have removed all the screws from the bottom of the laptop, and there may be screws in locations where the main battery, hard disk and CD/DVD drive was installed, Also there may be screws under the keyboard.
You need to remove the LCD screen (ie the hinges). You also may need to remove the plastic panel that houses the LED and push switches to get access to the video cable etc.
You should now be able to separate the case.
The two half of the laptop case are held together with plastic clips.The best way to separate the case is to start near a openning near the CD/DVD drive slot and gently prize the case apart until a clip catch releases and then work around the edges of the case in both directions until all the clips release.
I have found this method works best on various laptops.
Apr 11, 2009 | Acer Computers & Internet
Gateway 7330GZ PC Notebook screen going off and on
Ya, my 7330GZ has been having this problem. I did end up taking the screen apart.
Removing the little black nubs around the screen allow you to remove the screws, then you just use a flat headed screw driver to unclip around the edges (some can be stubborn, especially along the bottom).
The screen is glued to the casing along the top and bottom, so you have to gently separate the two.
After you have it opened up the screen has 3-4 screws along the left and right side (the right side is a pain to unscrew since the wireless antenna casing runs right along it).
Once you remove those screws you can take the screen out and get access to the ribbon cable running along the back.
Aug 11, 2008 | Gateway 7330GZ Notebook
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Sony VAIO CR320E/L T7250 2.0G 2GB 250GB DVDRW 14.1-WXGA XBE WVHP BLUE PC Notebook Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
