Question about Yamaha RXV-350 Receiver
VOLTAGE SELECTOR do I have to unscrew the back and change the voltage selector if im using 120 voltage
  • 757 Answers
Not if it wasn't manufactured for an area of use that is running something other than 120 volts. If it wasn't imported then plug it in and go.
Posted on Jun 18, 2009
A-p510 amp turns off as soon as it's turned on
maybe it's a fuse that automatically turns it off, send it to a service
Oct 16, 2013 | Pioneer Audio Players & Recorders
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
Jan 15, 2013 | Logitech Speakers. S-120
How do you change the voltage of a tv
The voltage that a set uses for power cannot be changed in most cases--if the set uses 110-120 Volts for power and you want to use it somewhere with say 220 volts--you buy a step down transformer which will convert it down to the lower voltage---if going from a source of 110-120 to a 220 source you buy a step up transformer.
May 30, 2012 | Televison & Video
Hp compaq dc7100 cmt can't start. 9 beeps and led red
9 beeps means that the input voltage to the PC's power supply is incorrect, have you changed the switch at the back of the PC from 110 to 240v or vice versa. If the PC was not bought in the UK then it may be set to 110v in which case the voltage selector at the back of the PC needs to be changed to 240v. If there is no voltage selector would recommend changing the power supply.
If by changing the selector to the correct voltage it still beeps 9 times you are looking at a new power supply unit which you can buy from HP at a high cost or buy a used one from:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160617535239
Hope this helps!!!
Jul 19, 2011 | HP Compaq dc7100 PC Desktop
I need an adapter for a double cassette deck CR-W223U to be able to plug into a outlet for 120 volts. Is it possible to buy one?
If it's not rated for 120v you can't just 'plug it in' unless it has a source voltage selector on it. Otherwise you will need a transformer to convert 120 to the desired voltage AND an adapter for whatever plug type you need. Google "plug converter for (whatever country)"
Apr 10, 2011 | Fisher Audio Players & Recorders
My last reference was incorrect. I have a Sony CDF in Greece. Will it play in the USA?
The voltage in Greece is 220volts and in USA is 120v. Now depending on where you bought it from there might be a voltage selector at the back ( near or inside the battery compartment you will find a slide switch - you will have to use a flat blade screwdriver to change voltage). Mostly only Asian models have 120/220v selector because Japan is 120v and the rest of Asia is 220.
Another way to find out if its multi voltage, check the sticker or engraving at the back it will be mentioned on it.
Apr 02, 2011 | Sony CFDS03CP CassetteCD Boombox
Dosnt turn connect to different outlets and nothing Can I send it to get repaired or what can I do
Most video displays will let you know that there is no video input with a display. If your unit is not turning on, make sure the outlet is powered. Take a lamp and plug it is the same outlet you were going to plug your TV into. This will determine if you have source voltage. If you do, then we can concentrate on the TV.
Assuming the plug works, check to see if ALL connections are secure and fully inserted in their sockets.
Finally, please make sure that the voltage selector (120/240) is selected to 120.
If the unit still will not power up, take it back.
Sep 26, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
How do i switch the Hz setting on the monitor
Usually, if there is a selector switch to match electrical requirements of a monitor or computer to that which may be available in the home, it is for voltage or voltage AND frequency. Seldom is there are selector for frequency only (I've yet to see one anyway).
The selector switch it typically found near where the AC mains power cord enters the enclosure. This can be on the monitor itself - or in the case of a monitor that uses a low voltage cable and connector connected to a power adapter, it would be located on the power adapter instead. Sometimes, these devices automatically detect and switch to match the power being supplied to it. The device should clearly indicate that it will work a wide range of voltages - do not assume it will if it does not specifically indicate that it will.
The selector above is set to 230 volts.
Set the selector switch BEFORE connecting to the power outlet. Most times, the selector switch has the voltage indicated on the slide. The switch will allow the user to choose 110-120 or 220-240 volts. The 110/120 selection is likely to be the 60 Hz variety and the 220/240 selection is likely to be 50 Hz.
If you are unable to locate such a switch, the device is not intended to be changed by the user - and there is likely no "easy way" for the user to change it.
Please rate this reply - good luck!
Aug 31, 2010 | Computers & Internet
230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Jul 21, 2009 | Cambridge Audio Azur 640A Amplifier
Yamaha RXV-350 Receiver Logo
81 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
