Question about JBL Venue SUB10 Subwoofer
My JBL Subwoofer won´t turn on. I have connected it to the AC outlet and tried switchinf it on and nothing happens. The back light doesn´t turn on and it does not seem to power up. What can I do?
sanjin
  • 56 Answers
SOURCE: clicking noise from subwoofer
Malfunction in the amp or to high signal on the input protect relay is cliping
Posted on Mar 23, 2008
Benimur
  • 6966 Answers
SOURCE: Subwoofer hum
Based on your description, the internal power supply of the subwoofer amplifier would be suspect. Often it would be a blistered or leaking filter capacitor. It is a relatively easy/inexpensive repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
SOURCE: Power supply malfunction
http://i38.tinypic.com/2mqw58l.jpg
Here's a picture of mine that caught on fire last night.
Posted on Nov 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 10, 2009
  • 45 Answers
SOURCE: My JBL PowerBass PB12 makes a continued loud sound when it is on
Have you tried turning the gain down before turning it on. If that works, it might be the internal amp picking up noise somewhere. Maybe even a bad ground. Either way there are only a few things you can try before complaining to the manufacturer or replacing it. Changing its location might help and if it does might indicate RF interference. You can also try running it through a power strip, one equipped with a filter (these are fairly common). Good luck
-Dynami
Posted on Mar 29, 2009
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
Jbl pb10 subwoofer will not come on, that is the two lights in the front will not come even though it is plugged-in
1/ Check the power outlet, dont laugh i have been caught by this one
2/ Is the power cord removable (2 or 3 pin) if so then try another cord.
3/ If not check to see if there is a power switch in the vicinity of the cord
I know it sounds stupid however it does happen.
4/ Check to see if there is a fuse in the same area.
5/ If not you will have to remove the cover back, front, or bottom
to gain acess to the internal power supply, there should be a fuse in
the power supply and or a fuse in the amplifier circuit and or the speaker line.
binary6
Sep 16, 2009 | JBL PB10 Subwoofer
Polaroid FLM 32" trying several times until it turn it on
You have a Power Supply issue probably with vented capacitors, have it looked at ASAP!
Jun 07, 2009 | Polaroid FLM-3201 Television
When i plug in my subwoofer it has a constant hum
Sounds like you have a bad connection somewhere. Make sure all of your connections are secure. If theres anything that is a little loose you'll get that hum. You might also try replacing your cable too. If it became pinched somewhere it could cause that problem
-Captain Jake
Feb 11, 2009 | JBL PB10 Subwoofer
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Aug 04, 2008 | JBL Venue SUB12 Subwoofer
JBL Venue SUB10 Subwoofer Logo
676 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
