Question about DeLonghi Coffee Makers & Espresso Machines
I have a 6 moth old Delonghi EC155 espresso maker. Yesterday it started spitting out light brown water from the steamer and it smells sort of like burnt rubber. What broke? Mark
  • DeLonghi Master
  • 1,711 Answers
The problem is that the steam thermostat is not working right and leave the boiler overheat enough to start burning the boiler pastic seal and also the overheated steam blow out some boiler dirt gather by previus use which was liying in the boiler and it was gather from water, soil is brown color.
So now if you are lucky first dont switch it on again since it might be on the starting of the problem and you can avoid it by just replacing the steam themostat. Howevr you must work it then without the top cover with extra safety of course in order to visual check if you have any other damage from the overheating like gasket burned out and or water leaking or else.
Good luck
Posted on Aug 21, 2010
Ec155 delonghi
if you have an ohmmeter, disconnect the cables that feed the resistance and connects the ends of the meter should give a value of element 5 to 30 ohm, if you give infinite that is very high due replacement it, there are also two thermostats one limit and a control, if you use this meter their connections resistance removing the cables connecting them, the measurement should be 0, if it gives you another value or infinite must change.
Feb 09, 2014 | DeLonghi EC155 Espresso Machine
Tip
DeLonghi EC155 Doesn't Release Water
When I bought my EC155, I heated it up for 30 minutes and tried multiple times to run water through. After multiple attempts the water level remained unchanged. <br /> I was able to fix the problem by opening the bottom of the machine (4 star screws). After opening the bottom, I immediately noticed that one of the plastic pipes was not in the channel in which it was supposed to be and as a result was kinked and sealed off. I simply pushed it into the channel and that fixed the problem.
on Sep 14, 2011 | DeLonghi EC155 Espresso Machine
Coffee stops flowing
Run a 50/ 50 vinegar & distilled water solution through it. Only use distilled or bottled, purified drinking water from now on.
Feb 17, 2013 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
I NEED A MANUAL SO I KNOW HOW TO USE MY dElongi Espresso EC155
You can download the user manual directly from Delonghi from this link
Sep 28, 2009 | DeLonghi EC155 Espresso Machine
DeLonghi EC155 Expresso Maker
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Feb 18, 2009 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Coffee Makers & Espresso Machines Logo
218 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
