Question about Kenmore Refrigerators
Kenmore Coldspot 50269992 Found freezer door ajar 24 hours ago. Ice was melting, food was thawing. Took out contents, cleaned up water. During night could hear a slight click sound periodically. This AM refrigerator side not as cold now, freezer side not evene cold. Used vacuum cleaned coils underneath. Checked backside, visually. I can see a fan (approx 5 inches) is running. I see a canister shape with copper tubing. This is the extent of my knowledge about this appliance. What should I do? Is there a Reset switch? Thanks, Larry Smith
  • Larry Aug 21, 2010
    Okay, I found it on the side of the compressor as you said. I removed it and the two wires. It does rattle when I shake it. I guess replacing this would be worth the money?
    Larry
  • 4,070 Answers
The click sound may be the compressor starter/overload relay trying to start the compressor(canister shape). It the compressor don't run it won't cool any. The starter could be bad and just need replacing. If the relay is burnt, bulging, or rattles when you shake it it's bad. If it's good then the compressor is probably bad and requires a serviceman to repair or get a new fridge based on the age of yours.
The relay is a (1x1)small squarish black thing near or on the compressor. I couldn't find a diagram using the model number you gave. Try this. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=50269992&pathTaken=partSearch
Posted on Aug 21, 2010
  • Charles T Nevin
    Charles T Nevin Aug 22, 2010
    Yes definitely. Thirty dollars or so for the relay and 300. to 600. for the compressor and labor.
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Freezer door won't open
k i would take say somthing hot or warm that you can melt the ice with (hot water in a contaner) and drag it aacross the ice
Jun 07, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Kenmore Elite side by side refrigerator/freezer and just had the ice dispenser motor replaced a month ago when we first moved in our new house. However, our daughter left the freezer door ajar...
It would not hurt the motor as they are built to be exposed to some degree of moisture if the defrost does not work i would check and see if something is jamming the actual mech. up. In my ice dispenser i had stuff fall in from the shelf's and seized up the motor. Any how if the thaw does not work check out a motor at repairclinic.com (http://www.repairclinic.com/SSPartDetail.aspx?s=t-106.53769202-%3d%3dc203i1057785&PartID=1057785)
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
