Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to print 51, Brother MFC-845CW - Brother MFC-5840CN All-In-One InkJet Printer
    Novelist:
    Champion:
  • 225 Answers
Error code #51 - encoder strip may be stained with ink, purge cam shaft broken.
Note: error codes for inkjet printers are different than lasers.
Posted on Oct 19, 2010
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: brother mfc-845cw error unable to print 4f
Hi there
Ok try see if this work.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: my brother printer mfc-845cw is giving me an error
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
SINN3D
  • 85 Answers
SOURCE: unable to print 51. what does this mean?
Here mate this should help: http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=eu&c=gb&lang=en&prod=mfc440cn_all&Cat=11
Posted on Jun 13, 2010
UNABLE TO PRINT BROTHER MFC-845CW #50
Hi Melanie,
Go To Below official Brother Printer Page For Your problem,
Frequently Asked Questions
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
May 22, 2014 | Brother MultiFunction Center MFC-440CN...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Printer screen reads unable to print 50on my MFC-845CW
I would reinstall the driver and see if that first fixes the problem. be sure to restart the printer and the computer after installing the driver.
You can find the driver from here:
http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=MFC845CW
Jul 15, 2011 | Brother MFC-845CW multi-function...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
My brother printer mfc-845cw is giving me an error unable to print 51 can you help me with it
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
Nov 09, 2009 | Brother MFC-845CW multi-function...
Unable to print copies
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Brother MFC-845CW InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Dec 29, 2007 | Brother MFC-845CW multi-function...
Brother MFC-5840CN All-In-One InkJet Printer Logo
1,118 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
