Question about Canon PowerShot A590 IS Digital Camera
My Canon A590 is stuck in 16x zoom (which it isn't supposed to have?). It powers on and off but it unresponsive to the other buttons. No more warranty.
Buy a new one. I am still trying to figure it out. If I pull on the lens a bit, when I restart, I get a normal view for one second and then zooms to 16x. It's a bummer, I love this camera. I used the macro a lot and noticed I was having trouble getting a clear focus before it did this.
Posted on Aug 29, 2010
Function buttons not working on canon a590
Since CHDK changeset #917 the <Alt> button can be set to PRINT (default) or DISPLAY from the "Miscellaneous stuff" / "<ALT> mode button" CHDK menu
  • If DISPLAY is selected for <Alt> button: press DISPLAY quickly it will act as your <ALT> mode button, but if you hold it down for a second, it acts like the DISPLAY button normally does
Performance chip
May 23, 2012 | Canon PowerShot A590 IS Digital Camera
Change the language from danish to English Canon PowerShot A590 IS Digital Camer
Set the mode switch to playback (right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use cursor-left/right to select the desired language. Press the FUNC/SET button.
May 16, 2012 | Canon PowerShot A590 IS Digital Camera
How could i change myself the zoom / lense of my canon A590 powershot? it is all bent after a fall on a hard floor
Have a look at this webpage, it shows in detail how to disassemble the A590:
http://pkrobot.freehostia.com/MiscElectronics2.htm
It is really pretty easy if you follow this guide.
Best regards,
Bob
Dec 08, 2009 | Canon PowerShot A590 IS Digital Camera
I have a canon A590 is camera. When I try to upload pictures onto the computer and plug the camera into the computer nothing happens.The camera does not power on like its suppose to. Why is this? I know...
Your USB cable is fine, I use a generic cable with my A590 with no problems. Connect the USB cable to the camera then your computer, make sure that the camera is set to the view setting instead of picture taking setting and then turn your camera an. Your computer should then see the camera. This is the only combination that works with my camera.
Best regards,
Bob
Nov 24, 2009 | Canon PowerShot A590 IS Digital Camera
Canon Power Shot A590 IS lens error message won't
Sending it to an authorized cannon repair facility. the lens must be replaced.
Sep 30, 2009 | Canon PowerShot A590 IS Digital Camera
Frozen
You have a stuck zoom switch. The fix will require opening the camera, see the following link. This detailed fix is courtesy xscrewdriver (nice job xs).
Aug 01, 2009 | Canon PowerShot A560 Digital Camera
Lens adapter ring stuck
As I recall you have to push in on the ring as you hold down the release button and twist. The store had problems with it too. Read the manual. Gene
May 13, 2009 | Canon PowerShot A590 IS Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
