Question about Hotpoint Dryers
I try to use my Hot Point dryer but it do not heat up. Everything works fine/ Tell me what could be wrong
    Champion:
  • 245 Answers
You could have a tripped breaker on your 220 breaker(two breakers beside each other) or one of your thermal cutoffs is bad or your element, or you have an obstruction in your vent. Good luck!
Posted on Aug 21, 2010
My maytag atlantis model #MDE6200ayw Serial #40504320zy is not getting hot. Everything else seems to be working fine. One thing i did have to do was change the prog back to the 3 prong as i just moved into...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
Hello Everyone I have Hot Point Dryer model NBXR333.Recentily have problem. The problem is the dryer not heat when start and end the cycle.The circle works good but not heat in any moment.
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 05, 2011 | Hotpoint NBXR333GGWW Gas Dryer
I have a hot point dryer model dlb265obdlwh not giving heat but will run
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 09, 2010 | Hotpoint Dryers
My Hot Point 5 cycle dryer is not gettting hot enough to dry
heatman101
Oct 26, 2010 | Hotpoint Dryers
The dryer does not get hot, it seems to tumble and do everything else ok but it is not getting hot or drying the clothes
heatman101
Oct 09, 2010 | LG DLE2514 Electric Dryer
My space saver dryer will not get hot ,everything else works fine
If everything else works, but not heating, than the problem is either:
Clogged air ducts
or
Heating element needs to be replaced.
Jun 05, 2009 | GE Spacemaker Washer and Dryer Electric...
My LG DLE5977W electrical dryer won't heat
bad thermostats or heat element broken
Feb 24, 2009 | LG DLE5977 Electric Dryer
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Heats up but not drying!!
The Vent is CLOGGED !!!!!!!!!!!!!!!!!!!!!!
TRUST ME
There is no other possible reason for the dryer taking a long time to dry other than vent restrictions or just poorly built duct.
DO NOT RUN THE DRYER WITH THE DOOR OPEN
Not only can it damage the dryer it can catch fire!!!
Jan 19, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
111 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
