Question about Husqvarna Freesia 415
I CAN'T REMEMBER HOW TO THREAD THE MACHINE AND I DON'T HAVE ENOUGH TIME TO ORDER A MANUAL!!
    Scholar:
  • 109 Answers
Put the thread on the spool pin and then put the spool cap on to hold it in place. Pull the thread out to the left and under the first little metal "t" and over the next metal finger, down under the tension disc and up through the channel staying to the right side and go from right to left around the back of the thread take up lever and back down the channel and around the little wire on the NEEDLE BAR and front to back through the needle. Do all this with the PRESSER FOOT UP. Let me know if you need any more help.
Posted on Aug 23, 2010
Euro-pro sew & go b410 sewing machine: Diagram on how to thread it?
Am unable to locate a picture of your machine, but the attached link is threading instructions for a 416. Perhaps it is close enough to your machine model to be beneficial:
Euro Pro 416 Sewing Machine Threading Diagram
Oh yes, one more HINT: ALWAYS RAISE the presser foot when threading the top thread!
Otherwise, search for:
Make Model threading
and see if anything comes up that is helpful.
Or try this manual:
https://www.manualslib.com/manual/918249/Euro-Pro-415qv.html?page=16#manual
Remember that sewing machines basically operate the same. Even though the design has changed over the years, the threading process and sequence remains the same.
Jul 08, 2017 | Euro-Pro Sewing Machines
Just bought Juki MO1000. Have threaded and re-threaded several times (easy enough) because the lower looper thread (position 1) thread breaks after sewing 4-5 inches. Any ideas?
Yep, 9 times out of 10 when thread breaks, something is not threaded correctly. Also, whenever thread breaks or becomes unthreaded, best policy is to unthread everything and start over from the beginning. Simply re-threading the broken thread will usually not work.
Remove all the thread from the machine. RAISE the presser foot (important to ALWAYS do this so the threads will seat properly in the tension disks).
Rethread totally from the beginning making sure to follow the threading instructions for each thread and that the threads are threaded in the ORDER (ie upper looper, then lower looper, then needles) per the manual. If the threads are not threaded in proper order, the machine will most likely never work.
When threading the lower looper, as the last step, be sure to pull the thread tail over the top of the upper looper mechanism before pulling the thread tails under the presser foot.
If the thread continues to break, make sure the tension for that disk is not set too tight. Loosen it up and see if that makes a difference. Most factory standard thread tensions are around the midway point between the high and low numbers. Then slight adjustments can be made from that setting to tweak the tension result.
Jan 29, 2016 | Juki Sewing Machines
I am unable to get the machine to 'chain'and just have four straight threads. What have I done incorrectly?
Sounds like the machine is not threaded properly. Consult your owner's manual and follow it step by step from the very beginning. Most of the time the threads must be threaded in a SPECIFIC order (ie upper looper, lower looper, right needle, left needle--or whatever order your manual specifies). The order MUST be followed or it will probably never sew correctly.
Also, make sure you are "seating" the threads in the tension disks (hold onto the thread above the disk and pull down gently on the thread below the disc--it should make a "popping" sound when it seats.
Raise the presser foot BEFORE you thread the needles.
Jul 16, 2015 | Sewing Machines
Husky lock 936 cover stitch troubleshooting
try a new needle
try rethreading that one needle
rethread the looper
if that doesn't help, then the machine may have a timing problem and would have to be checked
Jun 10, 2015 | Husqvarna Huskylock Computerized 936
I need a manual for a singer touch and sew machine. It,s pretty old so i gope you can help me. I don,t know how to wind the bobbin. Help!!
Unlikely you will get a manual but here are the instructions.
Presser foot up, thread the top of the machine as normal all the way and through the needle, open slide plate, push the little button to the side and the winder will raise, take the thread from the needle and wind it round a few times round the screw that holds the presser foot on, gently press on the foot control and the needle will go up and down winding the bobbin, when you have enough thread on the bobbin close the slide plate and you will hear the winder drop down, pull the thread to the back of the machine and you are ready to sew
Sep 14, 2013 | Sewing Machines
Need a manual for Singer sewing machine, model number 7442...need to know how to thread needle
You can download a manual for free from the Singer website, link is
http://www.singerco.com/uploads/download/465_7442_efs.pdf
just copy this link into your browser window and give it time to download as its a large pdf file. Once open on your screen, you can click the "clipboard" icon to save the file to somewhere on your PC. Then print it out and either bind up or put pages into a display book so its easy to flip through and stays with the machine.
Just remember to always thread up the top thread with the pressure foot up - this opens up the tension device so the thread can seat it correctly and is something often missed.
Also, use a new needle for each new sewing project, ie about 4-6 sewing hours change the needle and throw out the old one. A blunt needle is often the cause of bad stitching.
All sewing machines, whatever the make, will have similar key parts that are critical to threading up. These will be thread spool holder, the top thread tension device, thread take up lever, a couple of thread guides, the needle bar and needle. Thread in order from the spool down to the needle as per the threading diagram in your manual, ensuring you get the the thread into each thread guide fully, then thread the needle from front to back.
Place the wound bobbin into the bobbin case, it should rotate anticlockwise when you pull the thread tail. Now place the bobbin case into the machine using the latch, and it should lock into place when you let go the latch.
Now hold the top thread tail, wind the balance wheel (big one on the side of the machine) towards you to lower the needle through one stitch sequence so that the needle goes down then back up, now pull the top tail and the bobbin thread should be caught and pulled up to the top of the needle plate. Always hold both threads at the back of the needle plate as you start a new seam to ensure the threads don't get pulled down into the bobbin case/rotary hook area.
Nov 02, 2011 | Singer 7442 Mechanical Sewing Machine
I am getting birdnests under the strikeplate under the needle
try flipping the bobbin and bring thread up manual and bring thread to the front long enough to 7-8"
Sep 05, 2009 | Singer CE-200 Quantum Futura Computerized...
Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Sep 02, 2008 | Bernina 1008
Help I can't thread my machine!!
Hi Jacqueline....I can honestly tell you that nobody over the internet can be more helpful or effective than what you physically have available to you right now. I truly understand what you mean regarding the manual "teaching" you the correct threading order, so just put it at arms length for now. When you're ready, open your looper cover, and methodically study the color coded guides, visually tracing from spool holder to looper, working your way from right spool holder to left spool holder. Take your time, and if angst or frustration begin to creep up on you, just walk away, and continue when you WANT to. The repetition in visually studying the color guides will trigger your memory. And when it does, you're not going to remember the right way, instead, you're going to begin to understand what is wrong, and before you know it, you will be reaching for that manual, but this time, the manual will indeed provide your answers.....please update your post with developments, and I will continue to do my best to help you....good luck my friend
Aug 01, 2007 | Singer 14SH654
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
