Question about Sony VPLHW15 1080p SXRD Home Theater Projector
In my VPL-HW15 (SONY) the standby red lights flashes 12 times. It does not turn on, only flashes the red light. The fan does not start, and there is nothing in the manual about it. Couple of days ago it was complaining that the filter needed to be clean. I already cleaned the filter. Thank you, Mauricio.
  • 1 more comment
  • mrax1504 Aug 21, 2010
    Thank you for the quick reply.
    The problem is I am in Brazil, I dont think there is support for this projector down here. I've bought this in the US.
    Any other idea ? Isnt this a case of opening and cleaning ?
    The problem is that I am in Brazil, dont think there is support for this projector down here.
    I've bought this in the US. Any other suggestions ?
  • mrax1504 Aug 22, 2010
    Thank you my friend, will do that, let you know how it worked out.
    Best regards,
    Mauricio.
  • 10,594 Answers
Related service manual does not have 12 times red light blink error code details but in my opinion, it sounds temp sensor problem that is sending false signal to system control chip and preventing projector to power up.
This projector has at least 4 temp sensors inside and I would recommend to send it in nearest Sony service center for fix as it is not user level repair and requires qualified person to look into.
Hope these info will help you.
Thanks.
Posted on Aug 21, 2010
  • Shahid Electronics
    Shahid Electronics Aug 21, 2010
    Humm, this is real problem.
    Below is exploded view that shows boards location in this projector, temp sensors are located on V board, TL board. One is located in C board that is untouchable because that board is part of light engine (optic block)
    Check these temp sensors with help of local tv repair shop as they might help you to fix it.
    I'm afraid, thats all I can help you over internet.
    Thanks.
    Shahid Electronics Aug 22, 2010
    Thank you and good luck.
Sony VPL-ES7 projector boots up after few seconds switches off, with a red light flashing severally on the power button. Please what could be the problem because i have serviced the projector!!!!
Check the fan connections, one might not be connected right if you have just serviced it. Switching off with a flashing red light usually indicates a fan error.
Also is there a sequence to the flashes? e.g, 4 flashes and pause?
some manufacturers have a fault code table for the amount of flashes.
Nov 09, 2016 | Sony VPL-ES7 LCD Projector
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Dec 04, 2015 | Sony Office Equipment & Supplies
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony VPLHW15 1080p SXRD Home Theater Projector Logo
239 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
