Question about Sony Audio Players & Recorders
What lubricating oil to use on the shaft of the Technics SL DD33 and the tonearm bar of a Sony PS XL520 Linear Tracking TT? Hope someone can help me.
2 Suggested Answers
  • 11 Answers
SOURCE: Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Posted on Apr 13, 2009
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
My turntable is Technics model SL-DD33 and all of a sudden stop working I changed the power supply cord and it didn't fix the problem. Will you please advise or where I could take it for repair and if it...
Define what isn't working. Is it dead (no motor, lights, anything)?
Or is there just no sound. The output of the cartridge is independent of any power. A basic test to see if it's alive is to lift the tonearm, select the Phono on your electronics, TURN THE VOLUME WAY DOWN TO JUST A SKOOTCH OFF OF SILENCE, place the tonearm somewhere over the platter and lightly brush the stylus (BACK TO FRONT) with your finger tip. You'll hear objectionable noise from both channels if the conenctions are all intact.
Dec 12, 2009 | Technics SL-BD22 Turntable
How to install shure m44-7 cartridge on technic sl 1200.ive aproblem with the wt.,as i feel the shure cartridge is lighter then other cartridges do ihave to install extra wt. with the cartridge
No, you should not need to install extra weights. Adjust the tomearm counterweight (on the back of the tonearm).
Install new cartridge.
Set tracking force dial to zero.
Adjust counter weight so tonearm floats vertically. This is the balance point.
Dial in tracking force, 1 to 3 grams.
If you cannot achieve balance point then you may have to add weight between the cartridge and the cartridge mount
Oct 20, 2009 | Technics SL-1210 Turntable
Apr 07, 2009 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 11, 2008 | Technics SL-1210MK5 Turntable
Technics 1200M3D
These units do not leak oil. What you have there is just the old lubrication oil that is used for the tonearm height based. Nothing to fear, just clean it up. If you want, take it to a service center and have it professionally cleaned.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ Pro Audio Co.
Oct 04, 2008 | Technics SL-1200M3D Turntable
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
