Question about Sharp Microwave Ovens
The time display numbers are very dim and I can hardly read them.
  • Sharp Master
  • 9,047 Answers
There are two main causes for this dimming:
1. Dust & other particle buildup on the front of the display glass and the rear of the display window. This can be cleaned.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then...
2. Your vacuum display tube is wearing out and either the VFD display tube or the whole control circuit board must be replaced, depending on your model number, which you didn't mention.
If you'll contact me with your model number, I can give you an estimate and free do it yourself info.
Posted on Aug 23, 2010
Display on control panel is dim and hard to read.
If it's an LCD or LED display, it' may not be getting an adequate voltage from its driver I. C.. If fluorescent, it could be failing itself, or not be driven properly as well.
Based on other posts on this site,
The going rate for repair of these circuit boards seems to be about $39.
Apr 27, 2016 | GE Profile Spacemaker XL 1800 36"...
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
Are you able to get a VFD separately for Maytag MMV4205BAW to repair dim display panel without doing the entire panel?
The VFD (vacuum fluorescent display) tube is not available as a separate part for this model, so you would have to order a new control circuit board.
For model MMV4205BAW, the board's Amana part number W10127098 and it runs a hefty $232.30.
BUT -
if you order the board by the original Samsung part number, you can probably get it a for a lot less.
Here is a photo of a similar board which is marked to show you where to find the full part number.
You can find links to helpful exploded view diagrams and part ordering help here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is out, you disconnect the keypad, then take out your old board and put in the new one.
Some connectors may have a lock.
Oct 17, 2012 | Jenn-Air JMC7000 Microwave Oven
Dim Display Panel on Sharp Convection/Microwave R-1851
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
Mar 13, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Display is extremely dim to where you almost can't read it anymore
take down the display and clean the contacts if that does not work replace it.good luck.
Apr 27, 2007 | Sharp R-360E Microwave Oven
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Microwave Ovens Logo
173 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
