Question about Kenmore Dryers
I have a Kenmore 90 series electric dryer that will not heat. Model is 110.62922100. I have the schematic and have checked all the thermostats, thermal cutoffs,timer contacts,the motor rotational switch, and the element. Each of these items checks out for continuity, and I can read about 12 ohms from L1 to L2. Motor will run, but no heat. I am stumped. Thanks in advance.
    Champion:
  • 245 Answers
Check your breaker box. If one side trips it will run but will not heat. Common problem. Try checking L1 to N, and L2 to N, you should have 110 and 110 if you dont than it,s your breaker. I would just check your breakers. Make sure you give me a thumbs up if I am right.
Posted on Aug 21, 2010
Testimonial: "Yes sir, you are correct. I am embarrassed to say I didn't check that very fact first."
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Mar 24, 2010 | Kenmore 73952 Gas Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
218 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
