Question about Epson Stylus CX4800 All-In-One InkJet Printer
Paper Jam in Epson Stlus CX4800
How do I fix a paper jam in a Epson Stylus CX4800 printer??
I rescued it from the garbage & the scanner portion works like a charm!!
    Genius:
  • 3,587 Answers
Well..you may want to look inside, to see if there's any varmints in the paper path, eh?
Posted on May 04, 2008
I am getting the paper feeding down one side only... so it's a paper jam. Any ideas on how to make it work by pulling the paper down both sides instead of just one side?
Printers has a read-access panel where you can remove the jammed paper. This will ensure you will not damae the printer. DO NOT pull the paper in front.
Feb 14, 2011 | Epson Stylus CX4800 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson dx7400 printer jam
Turn off the printer and then open the scanner unit. Cancel the print job.
fon3_38.gif See Canceling Printing h018013h.gif step_2.gif Remove all of the paper inside, including any torn pieces. h018014h.gif step_3.gif Close the scanner unit and then turn on the printer. h018015h.gif
Aug 27, 2009 | Epson Stylus C86 InkJet Printer
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Error Light does not turn off!
Hi, it sounds like your printer experiencing a hardware failure thats why the error light still on. The sensor that detects paper jam or any obstruction might be defective. Aside from that your printer may also experienced a motion carriage error. You can to power cycle the printer & check ink cartridge. if the error still present your printer might be needed to be send to the nearest Epson Service center.
Tirzo
Mar 31, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
400 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
