Question about Maytag Neptune MDG5500AW Gas Dryer
Heat comes and goes, most of the time no heat but sometimes heat comes on
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
Heat will only heat for a few mins.
I would check the flame sensor and use steel wool clean the flame sensor or if you have a thermocoupler I would check that
Jan 21, 2018 | Heating & Cooling
Water gurgling in heater, heat is warm, air is very light coming out of the vents, sometimes air goes cold then comes back warm.. a bump will make it go cold
it's look like the a/c evaporator is block by dirt,oil look at it ..It should be clean as this one
hope it helps
Apr 04, 2014 | 2000 Chevrolet Blazer
88 nissan 300 zx ss fan and ac are on but only heat comes out.also sometimes it only goes threw the defrost and none to the floor or face vents
Check when you activate the hot cold switch that the heater tap is actually moveing. Your heater may be stuck on
Jun 27, 2012 | Cars & Trucks
Gaqs dryer does not dry no heat igniter comes on but only for short time. sometime burner lites but only for a few seconds
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][\
Jul 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
My Maytag Neptune sometimes ignites and heat comes on and other times, it will not and the clothes just spin on air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The vent was 90% crimped for a long time. The dryer heat comes and goes. Does a digital compputerized dryer have a thermal fuse that you can replace?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 25, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer not drying
On gas dryers an intermitting heat problem is almost always the coils on the gas valve. http://www.appliance-repair-it.com/
Sep 18, 2009 | Dryers
Fan for the heat and air works at times
It is connected to the thermostat to regulate the temp meaning when should the fan blow & when not. I dont know why the resistor will work, most pprobably a short-cut method to make it work till you replace the thermostat............sodeep
Jun 23, 2009 | 1994 Ford Explorer Limited
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Maytag Neptune MDG5500AW Gas Dryer Logo
217 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
