Question about Kenmore Vacuums
Hi, I have a Kenmore vacuum cleaner model number 20712008. There seems to be a problem with power getting to the suction base. There may be an electrical problem with the connector between the metal tube and the base.
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
  • 67 Answers
SOURCE: I have a Kenmore Progressive Inteleclean Upright
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Posted on Sep 22, 2009
SOURCE: I have a Kenmore Destiny Plus vacuum, and...
It's October now so this is probably too late to be useful for you but it might help someone: I had the same problem. I used a bright light to see that there was a clog up high in one of the plastic tubes on the side. Using an untwisted wire coat hanger I went up through the flap on the bottom of the vacuum. I pushed the cork screw end of the coat hangar up the tube and twisted it then pulled it out. It took three times to remove the clog completely but it worked. A plumber's snake might work even better.
Posted on Oct 28, 2009
SOURCE: We have a Kenmore Stylite
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Posted on Nov 12, 2009
  • 33 Answers
SOURCE: Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Posted on Jan 25, 2010
Sears kenmore vacuum 116.23401211C hardly used, suddenly no power at all. Cannot find manual, appears to be no fuse or reset on this model? Thx!
There is no fuse there is no reset either. If it doesn't run most likely the vacuum cleaner suction motor is defective or the power switch.
Feb 16, 2017 | Kenmore Vacuums
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
Suction tranfer
Hi there, it's Jack at Dyson.
DC24 includes a changeover valve which diverts suction power from the main cleaner head to the wand and hose, when you remove the wand from the vacuum.
If your machine doesn't seem to be diverting the suction correctly, we'd recommend checking for any obstructions in the ducts and at the base of the hose. Our online Support guide should help: http://www.dyson.co.uk/support/dc24new/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc24/check-the-wand-and-hosedc24
If you'd like further advice from our experts after giving this a try, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 25, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
My kenmore quick clean vacuum cleaner has no suction. Just seems to blow the dirt out and away from the cleaner. The canister is empty and the filter is clean, so what's going on?
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Apr 24, 2010 | Kenmore Quick Clean 30012 Vacuum
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Loss of suction!
you can tell if the vacuum is not run properly by the sound and no suction. check all the hoses and line, more likely is clog up and it the only reason why any vacuum cleaner seem to run louder and run hot due to the line is clog. check the hose line at the bottom of the base where the suction located with the pickup brush; it tend to get clog at the base.
Nov 23, 2009 | Dyson Vacuums
We have a Kenmore canister vacuum cleaner and the power in the floor component (rotating brush, etc) is no longer functioning. The vacuum is producing suction, but does not seem to be providing power to...
the problem could be with the power head itself or the hose providing the power. If you can turn the unit on from the handle, then its not the hose and you need to get a new power head..
Aug 14, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Vacuums Logo
49 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
