Question about Dryers
Hello, Im getting no flame from the ignitor. Does that need it needs to be replaced
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
Error code
make sure water filter is CLEAN ! this will throw a code
Jun 22, 2013 | Hayward H-series Electronic Gas Pool...
My bottom oven is not heating up past 270. Do I need to replace the ignitor?
Yes exactly if it takes forever to ignite or the flame is small the ignitor needs replacing
Aug 09, 2011 | Maytag Gemini 30" Self-Cleaning...
My gas dryer will not get warm
Can you hear the flame come on at all? If you can hear the flame come on in the beginning but then as time goes on it doesn't, you need to replace both coils (solenoids) on the gas valve.
Take the front panel off and watch the operation of the dryer. You should see the glow from the ignitor come on and get very hot, then hear the click of the coil releasing the gas, which will allow the flame to ignite. If you see the flame come on, stay there and keep an eye on the time.
After about 5 minutes if the coils click but the flame doesn't come on, you've just proved you need the coils.
If you have a meter you can check for continuity or ohm out the ignitor to see if that is your culprit. A less likely repair would be to replace the flame sensor.
Feb 19, 2011 | Kenmore Dryers
I have a Whirlpool Dryer. Model No.GGQ9800LW1. Dryer runs but does not get hot. I have replaced Flame sensor and the ignitor. what could it be?
Hello & Welcome to FixYa
As you have already replaced both flame sensor and ignitor & the problem is not solved so the problem is with the thermal fuse/thermostat going bad. Both these parts can be checked with a voltmeter for continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Dryers
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
Dryer spins, but no heat is generated. The dryer model number is 110.76662500
This could be one of the following:
* Defective ignitor. Suspected when ignitor fails to glow at all. Confirm by testing for 120v at the ignitor terminals. If present, ignitor is bad. Otherwise, suspect the flame sensor.
* Failed gas valve or holding valve coil. Run ohms check on each valve. May also need to actuate each valve with a test cord since that may only fail after being actuated a couple of times.
* One of the thermostats are open. Run continuity check.
* Bad flame sensor. If flame fails to ignite at all and the ignitor does is not getting 120v, suspect the flame sensor.
If you are not comfortable performing these checks, call in a repair person to check these components.
Hope this helps.
Sep 08, 2009 | Kenmore Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
Oven does not heat. Glow bar ignitor glows but no flame.
usually this means that your ignitor is weak and needs to be replaced. When the ignitor glows and NO gas flows through you need a new ignitor.
Jun 22, 2009 | Amana ARGS7650SS Gas Kitchen Range
Grill won't stop ignigting
See if the thermal bulb is in the flame, if not gently bend the bulb so that it is in the flame if that does not solve the problem you will have to replace the bulb to the igniter.
Jun 14, 2009 | Wolf Manufacturing Gas Kitchen Range
No Heat
Hello
Welcome to Fixya
Remove the vent line from the rear and try the dryer.
If it heats then that means there is a clog or kink in the vent line blocking the vent air from exiting which will stop the dryer from getting hot!
If not then it's another one of these problems.
Defective Ignitor (Gas Only)
When heated the ignitor used on your gas dryer must obtain a specific high temperature
in order to activate the flame sensor. This ignitor is fragile and susceptible to cracking.
A hairline fracture that is barely visible to the naked eye is enough to change
the resistance of the ignitor to a point that is will not work properly.
You can test the resistance of your ignitor. You should get a reading of 50-400 ohms of
resistance.
If the ignitor gets hot and then goes off after about 10-15 seconds and there is
no ignition, the problem is probably not the ignitor. It is most likely the gas valve
coils that are defective.
If the ignitor comes on and stays on, it is the flame sensor that is defective.
If the ignitor is not getting hot it could also be one of the thermostats that is defective.
The power for the ignitor is passed from the timer, through all of the thermostats,
limit switches and fuses to the ignitor. So if you are not getting power to the ignitor
during ignition, you should check the continuity of the individual thermostats and fuses.
DRYER DOES NOT HEAT
Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
Defective Flame Sensor (Gas Dryer Only)
The flame sensor's job is to monitor the ignitor for sufficient heat
to ignite the gas. A properly operating flame sensor will pass a
continuity check under room temperature.
Common Symptoms
If the flame sensor is defective in the open position,
the ignitor will not get hot when the dryer is started.
However, if it is defective in the closed position the ignitor
will get hot, but the flame sensor will not allow the flame to ignite.
In this case, the ignitor will usually stay hot for a long period of
time.
Defective Thermostat
The thermostats are responsible for maintaining the proper temperature
in the dryer. Check the exhaust temperature of the dyer and if the
temperature is above 150 degrees, you will most likely need to change
the operating thermostat.
The thermostat can also fail in the opposite mode.
It can prevent the element from heating at all.
A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw.
These thermostats are often used to control the timer when set to the
Automatic Dry cycle. If the dryer timer will advance in the Timed Dry
cycle but not the Automatic Dry cycle, then the thermostat could be the
problem.
Defective Thermal Fuse
The thermal fuse is in series with one leg of power to the motor.
If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according
to the model and brand of dryer.
Solution:
Check the thermal fuse for continuity with a volt/ohm meter.
If it is open, it will need to be replaced
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 25, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
