Question about Craftsman Saws
I have an older craftsman 10" tabel saw (Model: 113.298031) and the part listed in the parts list that I am replacing is; part #52, 3509, Housing,Arbor. I cannot remove the broken part from the main assmebly (not sure how it is held in place). I need help in removing the broken part and replace it with the new part. If you need to see a diagram I can email it to you. Thanks. Hide Comments
frcs68
  • 1605 Answers
SOURCE: How do you remove the arbor assembly on a craftsman 10" table saw
go to sears service center and get a new arbor, and ask them to show you the motor and arbor assembly drawing. it should show how the arbor is attached to the shaft.
you can pull the arbor off with a pulley. you can get that from auto parts store.
Posted on Apr 13, 2009
  • 10865 Answers
SOURCE: I need to change the blade on my 10 in. tabel saw,
OK. first of all unplug it. Then remove the plate that surrounds the blade. Wrenches came with the saw so hopefully you still have them.
You need two special wrenches which are sold at any sears hardware store if you don't have a set. The only thing to remember is that the outer nut has reverse threads so turn it clockwise to loosen it and counter clockwise to tighten it. Note the direction the saw teeth point in and duplicate that with the new blade.
Get back if you have any other questions.
Posted on May 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: how do you adjust the blade tilt past 0 on a sears 10" table saw
I don't know that particular model, but usually there is a stop under the table that the trunnion bumps against when you crank it over to 0. This is normally set by a stud or bolt with a lock nut on it that can be adjusted in or out to zero it out at 90 degrees...if you loosen the lock nut and change the adjustment you should be able to crank it over past zero a couple/few degrees as well...
You may need a flashlight to look up under there and locate the stop, then you merely stand on your head to adjust it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 09, 2009
  • 10 Answers
SOURCE: I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Posted on Feb 12, 2010
SOURCE: New or used motor for a Craftsman 10" table saw
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
Posted on Apr 17, 2010
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
I have a craftsman table saw.;;;;;;;;Not a power matic. I would like to know how the fence works and how the stops and adjustments work. There is a stop on the right side of the fence that I do not have...
I think you can download a manual for your saw from this link. or this link.
Another site I have had good luck with for these older models is here. Choose the publications/reprints tab at left, then choose craftsman in the manufacturer's link, and then click on machine type to sort the list into table saws. From there you might find a similar vintage manual that has the details you need. Many models have similar parts, and the descriptions of fence operation, etc are somewhat common.
Good luck.
Jul 29, 2011 | Powermatic 1660802K Model 66 Special...
I have a crftsman table saw mdl # 137228210 I purchased the saw used. I need a rip fence . the guides are allready there. any help would be appreciated
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Feb 09, 2011 | Craftsman 10" Table Saw
Need help locating a manual for an old Craftsman saw
Go to Searspartsdirect.com and list the complete model number minus the decimal point. You will get a series of drawings listing all of the replaceable parts and hopefully, the manual. Hope this helps!
Apr 29, 2010 | Saws
Blade guard broke
Go to Searspartsdirect.com and list the complete part number minus the decimal point. You will get a series of drawings of replaceable parts and can order from the site. Good luck!
Apr 17, 2010 | Craftsman 7-1/4" Circular Saw Blade Pack
Missing part for 12" "Craftsman" band saw.
Go to: Searsparts.com and list the model number from the machine. The have drawings of the unit (exploded) that list all of the parts used, although on older units, some of the major components are not available any longer. Hope this helps.
Oct 19, 2009 | Saws
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
May 03, 2009 | Craftsman 10" Table Saw
Boken shaft of old Craftsman skill saw
I have repaired many craftsman circular saws over the years and find that they share some parts with other brands. When sears drops a model number you must try to discover who made it for them. You did not list a model number, however when I need to identify a saw w/o the number I look at old part breakdowns and look on ebay for similar looking saws. Try and identify which manufacture made it for sears. Many were made by skill over the years so I start there. Once I find a good match, I check for available new parts. If not available, I check pawn shops and small tool repair shops for used parts, even burned out armature then have it rewound at www.eurton.com If you value your old saw take the extra time to look around, if not buy a good used saw at a pawn shop. I prefer Makita or Milwaukee good used about 40-70$; good used craftsman 20-30$, take a good look at the armature commutator and check that the arbor bearing is tight. Good Luck and email if you have questions.
Mar 30, 2009 | Craftsman Saws
Saws Logo
126 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
