Question about Brother Office Equipment & Supplies
My MFC-290C printer color ink pink is not functioning everthing is printing green what should I do
You don't think that maybe it's out of red? can you change one color at a time?
Posted on Aug 23, 2010
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
My colors are not printing right....things are
which means the cartridge do not have the equal amount of colors in it . refilling the cartridge will solve your problem .
Jul 04, 2010 | Brother MFC-290C Printer
Black not printing on brother mfc-290c! How do you clean the heads?
Press menu, thenpress 7, then press 2, it should say "cleaning." Select what color, press start, and your on your way!
May 12, 2010 | Brother Multi-Function Center MFC-240C...
Hi.. My Brothers MFC-290C printer is printing in pink. I need it to print black
Have you tried to clean the printer heads? usually there is a software application that will offer the ability to clean print heads, align the printer, shows the estimated ink level. This sounds like only one shade of your color head is coming thru.
Brian
Mar 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
MY mfc-290c does not print same colors as the photo in iphoto
Try printing the test print and see if all the colors are working, if some are missing you need to clean the printhead, and if you are using generic inks, sometimes the colors aren't as good as Brother inks.
Jul 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
61 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
