Question about HP LaserJet 2300d Printer
At work I have a LaserJet and for some reason it will only print from "tray 2" opposed to the normal "tray 1." How do you switch trays?
    Problem Solver:
  • 8 Answers
First what size is tray 1 set for and the type. generally tray 1 is set for letter size and the type is plain and usually is the normal default configuration.
also check the tray guides for proper setting letter size..
Also if possible run a configuration page to see how your current paper handling settings are being read by your printer.
the MP Tray is generally setup as ANY Size and ANY type always.
check your paper handling setup settings..there are additional steps, let me know.
Posted on Sep 11, 2010
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
Slow print come out with hp laserjet 4345 printer
dear friend,
for slow print many reasons:
1- check tray adjuster
2- check tray customs or standard lock( it will be right side tray lock)
3- check your printer driver
4- check printer firmware
5-check printer fuser
these are the reasons printer work slove
Mar 28, 2014 | HP LaserJet 4345mfp Printer
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
How to set printing to tray #2? HP Laser Jet printer won?t stay printing on tray 2- They do a lot of printing from this printer in the wire room and for some reason it will not stay printing on tray 2-...
Thanks for the inquiry.
Print a configuration page from the menu to determine what Tray 2 is set to.Pull Tray 2 and make sure the rear paper stop is set to Letterhead. Make sure it snaps into place and is not broken or loose. If it's broken you may have to replace the tray.
On your computer got to the printer driver icon and right click for properties. Make sure tray 2 is set to 8 1/2 x 11. Tray 2 should now be the default tray unless tray 1 (Manual Feed Tray) is open and then it will pull from it first.
Let us know how this works. We need to eliminate these setup issues 1st and more steps can be taken if necessary.
Thanks for contacting FixYa.
Oct 20, 2010 | HP LaserJet P4015N Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Printer only sends paper to tray 1 when printing from procomm...
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
Apr 09, 2009 | HP LaserJet P3005n Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
HP LaserJet 2300d Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
