Question about Broan-NuTone N-8664RP Combination Light Fan Exhaust Fan
15 year old bath fan/light noisy. rectangular 2 bulb model 164A-D
  • rkkilps May 03, 2008
    Broan model 164A-D
    Brigadier General:
  • 3,614 Answers
Have you check for the ballast, the noisy sound is coming from there, & need to be replace..
Thank you
Posted on May 03, 2008
  • micromaster
    micromaster May 03, 2008
    check also the motor and blower wheel..
    Guru:
  • 1,342 Answers
Could be that dirt and dust have collected on the fins over the years and are throwing them out of balance. You could try cleaning the fins on the fan.
The bearings may also be wearing out.
15 years is a good life for a fan.
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
My lights, indicators, speedometer and everything else on my dashboard isnt working. Where is the fuse located for these things?
What car : make, model, year? You said fuses were fine, ey? Something got disconnected, had any electrical work done recently? I had same issue on Honda Accord xl , 1990 model that I bought in 94 and sold a year later. After a guy had installed an alarm, they left a harness not hooked up. It was on dash or just under steering wheel on driver side. I cannot remember much that was over 15 years ago. There is a harness that controls all this accessible by popping out a black (1-2 inch) rectangular button, and reinserting it properly. It has pins similar to the ones used by non USB printer cables ( old ones, if you are not too young to remember).
Sep 26, 2012 | 2007 Fiat Grande Punto
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
Great nutone bath fan/light. just completed installation and fan makes soft noisy rattle when running. trick for silenting the noise would be great. thanks
if the blades are metal they may have been bent during installation. try to straighten them. make sure blades are not rubbing anything.
Oct 26, 2010 | Broan-NuTone Home
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Replaced bulb - no picture - blue dim light
Ur CRT need a rejuvenation,it a messy job.
It cost u the big screen repair shop about $300 dallors.
Sep 02, 2009 | Televison & Video
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Light blows when turned on
I had the same issue. Electrician pointed out my bulb was not 120v like it needs but 12v-hence the problem.....
Feb 03, 2008 | Minka Cirque Brushed Nickel- MinkaAire...
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Dryers Logo
198 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
