Question about Whirlpool Washing Machines
The center piece won't agitate anymore - Whirlpool Washing Machines
    President:
  • 1,218 Answers
Good day,
The agitator is a split unit. There are small devices called "dogs" that wear out. A picture is worth a thousand words, so go here. It will answer your question, and solve your problem
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on Aug 21, 2010
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator doesn't engage in roper AX5133 washing machine
Check these excellent youtube videos out I found while a surfin this here world wide web.
Old school washers:
Newer models:
May 29, 2010 | GE WWSR3090TWW
The center part that adgitates does not rotate as i think it should can i tighten it somehow
You need to remove the screw from the center of the agitator and pull up on the agitator from the bottom , to remove it . Seperate the 2 piece agitator , and replace the 4 agitator " dogs " . Reasemble . The " dogs " lets the top section of the agitator only move in 1 direction causing the clothes to " tumble " . OR , take the complete agitator to a parts house and they will install them for you .
May 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The plastic agitator isnt spinning it sounds as though the piece it sits on is turning but just spinning insde the plastic housing on the underside of the agitator
your "agitator coupling" is worn out underneath the agitator,remove the dispenser cup on t6he agitator,then the agitator,it sits on the coupler on splines and they wear out and the agitator can,t grip them anymore and slip
May 14, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
I think my wedding ring is in my GE washing machine. How to I pull the center piece out?
the top of the agitator(center piece) is a large screw, usually reverse threaded(this means it will be "righty loosy" and "lefty tighty"), then the whole agitator will lift off
Aug 14, 2009 | Washing Machines
I have found what appears to be pieces of the ceramic coating of the basket floating in the tub when starting to fill. From what I can feel and see, these pieces must be coming from under the agitator. How...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 04, 2009 | Kenmore Washing Machines
Aggitator working fine, however the plastic ''sleeve'' in middle covering it is noe catching to make it move. Can this part be replaced?
it can be fixed.what you need are agitator dogs.they go in the top part of agitator.you will need to pop cap off and take out one bolt in center if agitator.pull agitator aut and pull it apart.the center piece of the top part will have the old dogs on it.4 little pieces.very easy and cheap repair.
Mar 09, 2009 | Washing Machines
Noisy/loose agitator
remove the top piece of the agitator. this is a dispenser. then remove a cap that is at the center of the agitator. there is a bolt there that is holding the whole agitator. remove the bolt and you can pull out the whole agitator. be careful in removing, the thing could just separate to pieces and you may have a problem assembling it again.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
