Question about Whirlpool Duet GHW9150P Front Load Washer
I get FO2 code, (drain problem) I checked and ran water through the hose, it is clear, the hose is not kinked, nor is it clogged. What next?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
What does code f03 mean
An F03 error code on many front load washers indicates a failure to drain properly. You can usually clear this fault code by pressing the pause/cancel button. Next, check the drum for water. If the drum still has water in it, restart a drain and spin cycle. This should drain the water from the tub.
If your washer will not drain, check the drain hose for kinks or clogs. Make sure that the drain hose is not stuck more than 8 inches down the stand pipe.
If you do not hear your drain pump running, you may have a problem with your control or your drain pump. Also, if your pump is making a loud noise, it may be clogged. These problems would require service by a technician.
May 19, 2015 | Washing Machines
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Hello there
F/02 Long Drain
Nov 19, 2010 | Whirlpool Washing Machines
We just received an F2 error on the washer? how
Well it depends is it an F2 or an F02.. Two different codes.. an F2 code or and (F ) code could be electrical variables "F" Variables [F4 to F16] (Electrical Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START.
"FO2" (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Hope that helps I just went to www.sears.com/parts typed your model you were missing a diget on the end picked one located the owners manual on manage my home and went to trouble shooting all else fails it says calls for service.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine will not drain or spin
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Un plug the washer again for 30 seconds plug back in press the start/pause button then press power...This will try to reset your washer.. If it didnt work your pump must be checked...
Apr 19, 2010 | Roper RAS8445KQ Top Load Washer
GE top load washer will not advance to drain and spin
Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
Washing cylce completed but is not draining to begin the spinning cyle.
Apr 14, 2010 | Fisher and Paykel Washing Machines
I have a hmwm 6000 washing machine and i suspect the pump is blocked as it won't drain water. How do I get to the pump to unblock it?
Aug 30, 2009 | Washing Machines
I have just an "f" flashing can't find this code anywhere.
This is most likely an "FO2" Code.(Long drain). Any time the experiences a draining issue, this code will show. Check the following to address this issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FAGOR WASHER FAULT FO2 WHAT IS THIS CAUSE
I suspected suds build up, so I tried both regular wash cycles (e.g. Normal) and Rinse and Drain cycles multiple times to clear suds in the system, but still received the F02 error. Sometimes the SUD error message came up, but not consistently.
I ran the built-in Diagnostics tests. It made it to C:06 then got stuck.
In both scenarios above, the washing machine continued to try to pump water out, despite the fact that all the water had already been drained. After 8 or so minutes, the F02 error came on. As I understand it, if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
I performed the following with no success:
1. Check Wire Harness connections - OK
2. Check Drain pump. – OK, as water drains at a rapid rate
3. Check Drain pump motor - OK, as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – OK, ran a cable through both hose assemblies (exterior and interior) and not blocked.
5. Check the CCU – appears to function normally.
6. There were no kinks in the hoses, nor was the height of the pump beyond what the manual recommends.
After more diagnostics and troubleshooting, I found that the Pressure Switch was stuck and reported the SUDS state (continuity made between contacts 11 and 14 on the Pressure Switch itself). I ran many Rinse and Normal cycles with no detergent and still got this F02 error. I checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported the correct water level condition (EMPTY and Level 1). In all cases contacts 11 and 14 (SUDS) were continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
I removed the pressure switch and tested it by blowing into the inlet and did hear the switch click, so it seemed to work properly. Given the diagnostics above, I concluded that the pressure switch hose must have been clogged.
Good Luck!! Thanks for using FixYa!!
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
