Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
Mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Posted on Aug 21, 2010
The mower blades are engaged at all times. The switch that disengages blades does not work. A safety issue exists. What can you advise?
Sounds like the switch is defective and must be replaced..in the meantime...locate the wire connecting to the electric clutch fro the bad switch, shut the mower off and disconnect the wire from the clutch..you can operate the mower when not using the blades....just remember make sure you shut it down before attempting to pull the wire off the clutch..this is only a Temporary fix...good luck..
Jul 28, 2015 | Husqvarna YT48XLS 48 inch 24 HP Kawasaki...
Mower runs fine turn on blades it will die
MikeMake sure that the blades will turn by hand (key out of switch- unplug the sparkplug wires!!!!) there could be a dirt mound or rock jammed in there. OR-
if you\'re in the seat and the engine dies just as soon as the blades are engaged, the engine may need a tune-up. It sounds like it starves for fuel or air under load.
May 04, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower runs fine.when u turn on blades it will die
There is a switch under the seat made to turn off the engine when the blades are "on". You have to be sitting on the seat to engage the blades. If you are, check to see if that switch is plugged into the harness. If it already is, you probably need a new switch, or less likely, but possible, the harness is damaged somewhere up the line.
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a 48 inch craftsman riding mower. blades will only stay engaged for short period of time. what's wrong?
Most likely a faulty safety switch. Check the blade engagement switch and maybe even the seat safety switch.
Sep 18, 2010 | Craftsman Garden
Engine dies when i engage the blades on my craftsman 24hp 48" deck model dyt4000
There is a safety switch that is connected to the seat, so that if you get out of the seat with the blades running, it will shut the mower off. That switch may be bad, or disconnected. Look for a pair of wires running up under the bottom of the seat. As a short-term fix or a test, you could connect those two wires together.
Mar 07, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,783 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
